Thread: K1 Crawler Full Metal Axle
Old 11-04-2006, 02:19 PM   #1
Default K1 Crawler Full Metal Axle
We finally got the final specs down now. And we gave this axle an official name too.
We still on scheudle to ship the first patch around 20th of November.
Output shaft will be 5mm, so people can use it with R2 transmission. A special set of Punisher shaft will be made for K1.
Estimated Price for K1 will be around $200 to $250 (per axle). Axle housing, bevel gears and knuckles are aircraft grade aluminum, all other parts are steel.
Actual product preview will be on 15th November.
Again price is not final, we will know for sure at we come closer to deliver date.
K1 uses 12mm wheel hub (just like a clod), so people can use all the 14mm, 23mm adaptor, 12mm widener on it.
4 links and Servo mounts will be sold seperately.
We will make a smaller axle call K2 in December, it will be a little bit cheaper and a little bit more scale looking.
Old 11-04-2006, 02:25 PM   #2
looks good... i cant wait to try out some of the smaller scale axles...if you need a tester keep me in mind. my bronco tuber needs a set of them.
4stAir is offline   Reply With Quote
You may edit your posts
