Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: RCP Crawlers New Stainless Steel Locker for AX10 Axles
Old 10-01-2008, 11:12 AM   #1
Default RCP Crawlers New Stainless Steel Locker for AX10 Axles
RCP Crawlers New Stainless Steel Locker for AX10 Axles.
Our new stainless steel locker is the same diameter as the stock one, nice and heavy down low where you want it. It also has tighter tolerance on the holes that the axles fit into for little to no slop depending on the axle used.
Now Available at RCP Crawlers!
Reef is offline   Reply With Quote
Old 10-01-2008, 11:42 AM   #2
Are they any heavier than the 4130 chromoly lockers that stage three makes or for that matter any stronger? Not like they need to be stronger. Just wondering.
thunder7845 is offline   Reply With Quote
Old 10-01-2008, 12:18 PM   #3
I just went and checked the stage 3 site. They appear to be similar in shape (same as stock) Stainless and alloy steel are almost identical in weight.
Rockpiledriver is offline   Reply With Quote
Old 10-16-2008, 04:28 PM   #4
I bought these today, I'm not mistaken that axial or WK gears simply bolt to them right?
coolkidjf7 is offline   Reply With Quote
Old 10-16-2008, 05:24 PM   #5
The WK gears fit the BonusLine spools perfectly...so I would bet that they would fit these too
Trugg is offline   Reply With Quote
You may edit your posts
