Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Wreckluse Feedback, Support & FAQ
Old 08-31-2011, 04:11 PM   #181
I ordered my Wreckluse from RCPcrawlers recently. Should be here soon. Im excited to start my build!
Die-Laughing is offline   Reply With Quote
Old 09-01-2011, 09:42 AM   #182
Rock Slayer
TrailDawg362's Avatar
You're going to love your new chassis, have fun building it. Post up some pics when you're done .
Any update on replacement body panels? I know it's a long-shot but I just had to ask.
TrailDawg362 is offline   Reply With Quote
Old 09-01-2011, 06:55 PM   #183
RCP CRAWLERS
ZoSo's Avatar
[QUOTE=
Any update on replacement body panels? I know it's a long-shot but I just had to ask.[/QUOTE]
not yet.... I think I have too many irons in the fire
ZoSo is offline   Reply With Quote
Old 10-02-2011, 08:53 AM   #184
What hoods/bodies fit the Wreckluse?
HillbillyCrawler is offline   Reply With Quote
Old 10-02-2011, 10:28 AM   #185
RCP CRAWLERS
ZoSo's Avatar
jeep wrangler
I've seen the 70's bronco
and the large 70's chevy truck
I'm going to try a new bright JK Jeep hardbody front
I've seen a few hard body front ends that look great
Old 11-07-2011, 09:56 AM   #186
I am glad that I found this thread. It answered most of my questions. Can't wait to order mine in a few days.
JasonW is offline   Reply With Quote
Old 11-07-2011, 02:33 PM   #187
Originally Posted by jca2184 View Post
I use a set of integy 15mm wideners but they really hinder you on pointy rocks or narrow paths im actually about to remove mine but as far as stability goes they do help out
How wide do the wheels set apart now?
Old 11-07-2011, 04:59 PM   #188
RCP CRAWLERS
ZoSo's Avatar
most guys run the AX10 axles
you can run 1.9 or 2.2 rims and tires
you can also stretch the Wheel Base if you like
for better approach on the really steep stuff.
I've seen a wide variety of set-ups
The Wreckluse a great platform to start with
Old 11-10-2011, 08:55 PM   #189
The great customer support meant a lot when i called. Very few companies take the time to actually help customers like you guys do. I look forward to placing my order next week as well as a few others for my build. Thanks.
Old 11-26-2011, 07:53 PM   #190
Originally Posted by ZoSo View Post
HPI makes hundreds of bodies at a time and sell's them for 28.00.
....not a bad deal
I'll check to see the cost to run a hundred or so.
Is anyone interested in a carbon-fiber Wreckluse hood?
Did you ever have a chance to check into making replacement (flat) body panels?
MNROKCRAWLR is offline   Reply With Quote
Old 11-27-2011, 08:30 AM   #191
RCP CRAWLERS
ZoSo's Avatar
it's the minimum order that makes it unreasonable
I can create a cad file you could use as a template
to cut your own ...out of beer cans or flat lexan
Old 12-14-2011, 10:40 PM   #192
Default Re: Wreckluse Feedback, Support & FAQ
Can I get that file by chance? Pm me please, thanks!
crowninshield3 is offline   Reply With Quote
Old 12-15-2011, 01:50 PM   #193
I would for sure buy a carbonfiber hood, and I would be interested in those cad drawings to make me some panels
dblrnut is offline   Reply With Quote
Old 12-16-2011, 11:44 AM   #194
RCP CRAWLERS
ZoSo's Avatar
I'll get to it after the holidays
Old 02-10-2012, 08:26 PM   #195
Would the Axial SCX10 Honcho axles and tranny work okay with the wrekluse chassis?
ndi_guy is offline   Reply With Quote
Old 02-11-2012, 10:40 AM   #196
RCP CRAWLERS
ZoSo's Avatar
that's what it's made for...they bolt right up
skid is drilled for the Axial tranny
check out my Wreckluse ...just buy the links
RCP Wreckluse
Old 03-13-2012, 01:25 PM   #197
Replacement panels ??? When will they be available ???
ezee is offline   Reply With Quote
Old 03-28-2012, 11:29 AM   #198
Did you ever make that CAD file for the panels?
If not, i'm going to try and use my plastic ones as a guide. :(
hscrugby is offline   Reply With Quote
Old 03-29-2012, 08:32 AM   #199
Rock Slayer
That's what I ended up doing. I went with aluminum sheet material for the lower belly plates and repainted the outside of the original hood and clearcoated it. Stock replacements would have been nice though .
Old 03-31-2012, 10:30 PM   #200
I would be intrested in getting this cad file also if possible.
scott83 is offline   Reply With Quote
You may edit your posts
