Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Wreckluse Feedback, Support & FAQ
Old 10-03-2010, 07:22 PM   #141
they sleep wit da fishes...ZzzZZZZzzzz
I gave up waiting...on to the next idea
irok is offline   Reply With Quote
Old 10-06-2010, 12:04 PM   #142
I joined the Band!
I still have one of these chassis for sale if anyone wants one!
http://www.rccrawler.com/forum/showthread.php?t=268391
jtice is offline   Reply With Quote
Old 10-18-2010, 02:14 PM   #143
Has anyone had trouble with setting the pinion angle so that the drivelines don't hit the skid.
NorZepol is offline   Reply With Quote
Old 12-18-2010, 08:02 AM   #144
RCP CRAWLERS
ZoSo's Avatar
yes... depending on the ride height
dremel away the skid plate where the shaft hits.
ZoSo is offline   Reply With Quote
Old 01-01-2011, 04:00 PM   #145
I just got my wreckluse in the mail and saw this thread but I still have a questions. Will the wheelbase be at 12.5" with 55mm front upper links and 70mm lower and rear upper links?
Axial32 is offline   Reply With Quote
Old 01-02-2011, 08:25 AM   #146
RCP CRAWLERS
ZoSo's Avatar
that is correct
Old 01-02-2011, 10:36 PM   #147
I used a Dremel sanding drum to nicely bevel out a clearance channel for the driveshaft. Mark both sides where it hits the skid, and angle a groove into the material
TrailDawg362 is offline   Reply With Quote
Old 01-22-2011, 10:20 PM   #148
i did my truck just like this set up with 100mm shocks and i dont get that good of suspension flex. dose any one had that problem to.
johnnybrcman7 is offline   Reply With Quote
Old 01-26-2011, 11:58 AM   #149
Default wreckluse hoods
do you guys have any of the replacement hoods avalible for the wreckluse
herman712 is offline   Reply With Quote
Old 01-27-2011, 10:34 AM   #150
RCP CRAWLERS
ZoSo's Avatar
not at the moment...but you can cut up the HPI rubicon body
here it is:
Wrecker's 2.2 Wreckluse
Old 03-02-2011, 11:32 AM   #151
Do you guys sale the Delrin skid for the Wreckluse? If not, where can I get a blank Delrin Piece to make my own?
Thanks
hardheaded is offline   Reply With Quote
Old 03-02-2011, 12:17 PM   #152
RCP CRAWLERS
ZoSo's Avatar
Thanks
I'll look into make some extra.....maybe with the bottom links inset
Old 03-03-2011, 12:32 PM   #153
x2
Old 03-03-2011, 03:06 PM   #154
X3 I tried to inboard my lower links but didn't cut it right. I might be able to clean up my cuts but a new skid would be great esp. with the links inboarded. I've put my wreckluse on the back burner for a while but I'm about ready to start to work on it soon. Let us know if you do, thanks
3jeeps is offline   Reply With Quote
Old 03-10-2011, 09:54 AM   #155
Hey does anyone know what size hex screws they use for the body panels? I'm in need of a few
Old 03-12-2011, 01:04 AM   #156
RCP CRAWLERS
ZoSo's Avatar
they are 3mm button head 6mm long
Old 03-12-2011, 01:09 AM   #157
RCP CRAWLERS
ZoSo's Avatar
I'm in the process of make a new comp chassis and skid plate
so yes... I'll add the Wreckluse inboard skidplate to the order
I'll try and get them on the site in a couple of weeks.
Old 03-24-2011, 03:52 PM   #158
I just checked the site and I didn't see them yet, will they show up in the chassis section. I'll keep checking back but if you could pm me that would be great. I'm not in a big rush but I do want one and thanks for making them!
Old 03-31-2011, 12:21 PM   #159
Hey ZoSo-Wondering if you guys can or would do a run of replacement body panels, less the hood? I know I could cut some from flat lexan, but I'd rather just buy factory fresh pieces. Thanks!
MNROKCRAWLR is offline   Reply With Quote
Old 03-31-2011, 03:22 PM   #160
Not to beat a dead horse, but I've been asking the same question for awhile now. Yes, I know I could buy a body for about $28 and hack it up for a hood (and throw away the rest?). And yes I know I could cut my own panels (but not as neatly). Would it really be that big of a deal to sell the replacements? I'm not trying to be a jerk, but I just can't understand why it's so hard to offer them for sale. I love my Wreckluse, but it's getting pretty beat up and needs some new skins.
You may edit your posts
