![]() | #21 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
| ![]() Quote:
We are going to be bundling these with AX10 ARTR's tomorrow. The only additional pieces used to bolt this chassis to a a stock ax10 are the following. a 25mm axial spacer (axa1422 or equivilent) and a 3mm x 20 mm set screw. The 25mm spacer goes in between the upper link mount and the Y adapter on the rear axle. We also rcommend, and will include a set of our internal droop springs. (12200) | |
![]() | #22 |
Pebble Pounder ![]() Join Date: Dec 2004 Location: Acton
OK , Well What I used were Traxxas Ti turnbuckles off my Koala Chassis I beleive 9807 not sure though on the traxxas part with tcs 4 link plate. Its the ones everybody used to use whith TLT and SW2 chassis.
Last edited by rockbender; 12-22-2008 at 08:49 PM. Reason: misspeeellleddd wwoooorrrds |
![]() | #23 |
Newbie Join Date: Sep 2005 Location: Quebec, Canada
The R2D does'nt fit into the chassis. :-(
![]() | #24 |
Rock Stacker Join Date: Dec 2006 Location: USA
my r2d fits with a crawlmaster motor.
![]() | #25 |
Quarry Creeper Join Date: May 2007 Location: Rancho Cambodia
I had to use a little force to spread the chassis open to get my derlin skid for the R2d in and I also had to cut out the back cross tube to fit the motor.
![]() | #26 |
The first 15 min. were amazing, felt like I had rock magnets in my tires. After that a minor flop not even a roll or tumble and ... ![]() My theory is, the brackets for all of the mounts are only TIG fused on one side, so with a side to side force seems the brittle fused weld would be compramised or in my case crack. I love the chassis so I have no problem making the repairs myself. The majority of the clips on the inside are fillet welds, so I'll be able to use some filler rod. I dont mean to discurage and buyers, because i would still buy it again just make those changes right off the bat. |
![]() | #27 | |
Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| ![]() Quote:
![]() | #28 |
No stand off's. And that probably would have prevented it, but if you were to see how slight the roll was to cause the break, I think it would raise your eye brow too. I was shocked, I thought I forgot to tighten a bolt on my shock cause it literaly popped right off.
![]() | #29 | |
| ![]() Quote:
![]() | #30 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
I like!
![]() | #31 |
About 15 min. of work, and no need to run standoffs anymore ![]() ![]() ![]() |
![]() | #32 |
![]() | #33 |
What makes you say that? For the hoops that the tabs mount to?
![]() | #34 |
Yes. This chassis was designed to run the spacer to support the shock towers. If you happen to fall off a large enough obstacle the shock towers could bend without the standoff.
![]() | #35 |
Makes sense, ill take your advice. Thanks. BTW, when are those hoods comin out?
![]() | #36 |
![]() | #37 |
Newbie Join Date: May 2008 Location: Bakersfield
Hey guys wanted to say thank you for all the help when i came in today. I got my stuff home and started putting my new bastard jr together. This thing is awesome. One question ,i thought i had a different motor but i have a novak 55. Does this motor supposed to fit .?? i tried flipping the trany mount but still no luck . I believe nathan asked me if i had a goat..Is that the motor that fits ??lol Hey thanks again guys for the help and cant wait to come down and play on the rocks..
![]() | #38 |
The Novak 55 should fit easier than the goat as it is shorter. The guy making the hoods is supposed to be pulling some later this week. |
![]() | #39 |
Rock Crawler Join Date: Apr 2008 Location: SO CAL
ive been itching to get this chassis man, my Wrekluse is top notch and needs a buddy ![]() |
![]() | #40 |
Pebble Pounder Join Date: Feb 2008 Location: 801rcc
When will spare panels be available? Also any chance of the molded hood becoming available? Love the chassis though little difficult to hide electronics but still worth the time.
