04-21-2011, 08:48 AM | #41 |
Pebble Pounder Join Date: Oct 2010 Location: Jewel of the Sierra
This is the Chassis I have been waiting for! Solid Design! |
04-22-2011, 02:49 PM | #42 |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
04-25-2011, 12:02 AM | #43 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
I am going to be watching these chassis. Awesome design,and great innovation. I may have missed it but will this be sold as side plates/skid only or is there a kit avail with links? |
04-25-2011, 08:14 AM | #44 | |
RCP CRAWLERS Join Date: Nov 2007 Location: Upland CA
we will add delrin links and spacers when ready here's a link to the presale: Progress presale | |
05-23-2011, 09:04 PM | #45 |
here is the basic XR10 set up for links and ballends XR10 is running: 73mm upper front link (long bent ballends at chassis / long straight ballends axle) 94mm upper rear link (short bent ballends) high clearance bottom links front bottom links (AX80005 tree 6 front bent ballend / short bent ballends at chassis) rear bottom links (all long bent ballends) we trimed ballends and links to get the ballends to rotate tightly into the correct positions rear shock arm is 5 degrees up from level ground and shock is in the 1st hole (closest to chassis) front shock arm is 50 degrees up from level ground and the shock is in the 3rd hole (away from chassis) upper links mount to 3rd hole from bottom on chassis |
06-09-2011, 11:39 PM | #46 |
Pebble Pounder Join Date: Mar 2009 Location: Grande Prairie A.B
Just Received mine yesterday and Dam it's a nice chassis , I stayed up till 3 am getting it together and ready and thanks for your setup tips. This chassis made a hughe improvement on my truck it does breakovers i could never imagine doing before with the stocker chassis and side hills like a son of a beach . Great design Guys keep up the GOOD WORK |
06-10-2011, 06:05 PM | #47 | |
it takes a little effort.... but once you get her dialed in she can do.... what others can't!!!!! | |
06-10-2011, 10:49 PM | #48 |
| I'm sure once i get her dialed in she will domonate i was making the 2 Bully's work there ass off to keep up with where i was going already so i can't wait to see them crumble under the pressure |
06-12-2011, 01:12 PM | #49 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
06-13-2011, 07:19 PM | #50 |
06-16-2011, 07:16 AM | #51 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
I ordered my chassis the other day! I'd like to see some videos of these crawlers doing some work, and more pics/info on the builds. Finished set up pics would be great too!
07-13-2011, 11:22 AM | #52 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
Hey won this at the AWCC , do you know what people are using for the lower links on a berg. Also this thing looks great i'll be using a JFD bodyless on it any help would be great thax,here are some pics. Hope you like it. |
07-13-2011, 09:01 PM | #53 |
looks nice.... I have one in the works
07-18-2011, 01:13 AM | #54 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
Took my finished progress out today for its first real run and all I can say is this is easily the best chassis I've run yet.....it was a real bitch to build and get right with my berg axles but it was all worth it. Ultra light and predictable as hell, I even cut down on wheel weights....it just works for me..one day i'll figure out how to post pics and I will put them on here....thanks RCP
10-01-2011, 02:29 PM | #55 | |
here's the Bodyless Prototype being built for the Progress Chassis | |
10-01-2011, 10:18 PM | #56 |
Rock Crawler Join Date: May 2007 Location: Arnold
Price?Looks like you won't be needing the Axial XR10 shock mounting parts.I kinda like running a body again on my berg progress chassis.
10-03-2011, 08:12 PM | #57 |
11-24-2011, 02:57 AM | #58 |
Newbie Join Date: Dec 2008 Location: FRANCE
Do you know where can I find tutorial or instructions to use this Progress Chassis with Berg axles ? I'm very interested in this chassis, and I'd like to order it, but I need to now what else I have to order to use my Berg axles. Thanks guys... |
11-24-2011, 11:20 AM | #59 |
here's is my berg: Progress Berg I run the standard Axial hi clearance links I have shorten the front links to make it cab forward and added Jato ballends to extend the rear links.(I drilled and tapped for 4mm) the upper links can be straight links with just a small bend 10-15 degrees you want to avoid any links touching at full articulation and at full compression....it's a tight tolerance...but once you got it your set. I'm making a few changes to the bodyless topper...will be out soon! Thanks Dave |
11-24-2011, 12:20 PM | #60 |
Thanks for you link and setup Zoso, that's a good help for me |
