Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Rcp progress chassis
Old 04-15-2012, 10:30 AM   #81
Default Re: Rcp progress chassis
Any updates on a Cf version?
Silverdirt is offline   Reply With Quote
Old 04-16-2012, 08:00 AM   #82
RCP CRAWLERS
ZoSo's Avatar
well after tearing the CF chassis apart on the rocks
I built a 1/16 Aluminum chassis for more testing
so far it has worked great....I'll post up some more pics
when I get the chance....I'm running it as a bodiless pick-up truck
ZoSo is offline   Reply With Quote
Old 04-16-2012, 09:24 AM   #83
Nice i would like to see what you have for a cab.....
Random Hero is offline   Reply With Quote
Old 04-16-2012, 10:10 AM   #84
RCP CRAWLERS
ZoSo's Avatar
I'll send you the 2.2 cab and the super cab this week
Old 04-16-2012, 02:12 PM   #85
OH YA!!!
Old 05-13-2012, 01:51 PM   #86
RCP CRAWLERS
ZoSo's Avatar
The new Progress prototype
the proto is the same...without the adjustable arms=to save weight
and is 3/32 Aluminum ...The CF could not handle the abuse
Old 05-21-2012, 08:33 AM   #87
LOOKS GOOD DAVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 05-23-2012, 06:47 PM   #88
RCP CRAWLERS
ZoSo's Avatar
did you see sococrawlers build
I'm Baaaaacccccckkkkkk xr10 !!!!!
we'll be up at the Pacfic Coast Championships in June
Looks like a tough field of great drivers
Old 05-27-2012, 05:45 PM   #89
Relaxed !
sococrawler's Avatar
Got to run this yesterday and all I can say is wow ! Easily built no nonsense and strong as well as ultralight at (2oz) chassis only
My rig weighs in at 4.978 rtr it's light,I'm gonna add more weight just to make me happy
Thanks to Dave n Susie once again
sococrawler is offline   Reply With Quote
Old 06-25-2012, 10:45 AM   #90
RCP CRAWLERS
ZoSo's Avatar
the rig did well in the SoCal Regionals...low score on two of the courses
and after the Pacific Coast Championships and the VanHalen concert
I decided to go with a new theme for my XR10
Diver Down
Old 07-31-2012, 06:26 PM   #91
looks good Dave!!!!
Diver Down
Old 08-01-2012, 06:25 AM   #92
Lookin' good Dave!
You can now be totally wasted, and still be able to tell which way it is going
Hope to see you at Nats man!
TJ Steve is offline   Reply With Quote
Old 08-26-2012, 06:40 PM   #93
RCP CRAWLERS
ZoSo's Avatar
Hey TJ .... loading up giveaways and getting rigs ready for Nats...
just changed all the electronics in the Progress II
Dual Micro Sidewinders
new Castle BEC
(2) 35t Tekin Heavy Duty (35t HH are being rebuilt)
4pk and receiver
GEN 450 Batteries
Hitec 7950
Old 08-27-2012, 09:29 AM   #94
RCP CRAWLERS
ZoSo's Avatar
new Progress designs....coming soon
The New Progress Line-up:
Old 10-12-2012, 10:47 PM   #95
RCP CRAWLERS
ZoSo's Avatar
The Tomer 3.5 ready for testing:
Old 11-28-2012, 01:06 PM   #96
RCP CRAWLERS
ZoSo's Avatar
I've had a few customers ask for the original Progress link dimensions
the best way to get the links right ...set up about 60/40...
rear bottom link 143mm
top rear link 133mm on 8mm stand-off
front bottom link 123mm
front top link 107mm on 8mm stand-off
Old 12-06-2012, 03:26 PM   #97
does the progress 2 use the same links?
rockseeker is offline   Reply With Quote
Old 12-11-2012, 09:31 AM   #98
RCP CRAWLERS
ZoSo's Avatar
yes the progress II takes the same links
as soon as the drivers get their new chassis
I'll take pics and get the specs for links and shocks
the Tomer will require different upper links
Old 12-21-2012, 05:26 PM   #99
I have the progress 1 chassis and am having trouble dialing it just right so it doesnt flip on its back claiming hills I'm running stock rx 10 links bent uppers and straight lowers any ideas or anything would be helpfull for any specific places for link hole and shock mounting points
jimmyt13 is offline   Reply With Quote
Old 12-21-2012, 07:07 PM   #100
RCP CRAWLERS
ZoSo's Avatar
Hey Jimmy here's the set up that works for me
keep the upper links level to the ground (top or middle chassis hole)
use a 1/4" stand-off on the outside of chassis front and rear
this will give you better balance when articulating
make sure none of the links are binding at full articulation or full compression
I use Losi 4" shocks with Losi gold springs outside and RCP internal springs....shock ends up about 3-5/8" at full extension.
You may edit your posts
