09-02-2007, 06:30 PM | #181 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
09-04-2007, 09:54 AM | #182 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Thanks, John | |
09-04-2007, 10:49 AM | #183 |
Thanks John and Brian for keeping newcomers interested and giving away all these prizes...just hurry up with my super hustler |
09-04-2007, 12:05 PM | #184 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
hey RCP, being trying to contact you for days now, hope you can answer my emails. Ben |
09-04-2007, 12:37 PM | #185 |
Pebble Pounder Join Date: Jul 2007 Location: neptune
He has been at the Fontana Racetrack along with HPI and they had a booth there. Give him a chance to catch up, John will answer!!
09-04-2007, 12:43 PM | #186 |
09-04-2007, 01:25 PM | #187 |
Quarry Creeper Join Date: Feb 2007 Location: Fresno
09-05-2007, 04:38 PM | #188 |
Quarry Creeper Join Date: Sep 2006 Location: nor cal
JOHN, whats up with the 2.2 cvd's? i have broken 3 bell's in less then a month. i sent you an e-mail, havent heard from anyone. let me know. thank's....
09-06-2007, 08:07 AM | #189 | |
Just checked my emails and PM's back 2 weeks and I don't see your message anywhere. Please send a PM via this forum and I will respond now. Thanks, John | |
09-06-2007, 08:52 AM | #190 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Why are WK CVD's $15 cheaper than TLT CVD's?
09-06-2007, 09:30 AM | #191 |
09-06-2007, 09:32 AM | #192 |
Is that going to make its way to the TLT CVD's?
09-06-2007, 09:41 AM | #193 |
09-06-2007, 11:30 AM | #194 |
09-06-2007, 03:06 PM | #195 |
Rock Stacker Join Date: Feb 2007 Location: Cincinnati
Can someone please reply to my email regarding my messed up ring gear? It came from the address Xx5Link5xX@aol.com. I sent it two days ago and have heard nothing and my friend sent one yesterday and got his replacement parts today.
09-06-2007, 08:29 PM | #196 |
Quarry Creeper Join Date: Nov 2005 Location: ov'a hea
axle c's! axle c's! axle c's! when will you have them in stock again? i need them, can't do any crawling until i get some. thanks' |
09-07-2007, 03:24 PM | #197 |
09-07-2007, 03:25 PM | #198 | |
thanks, john | |
09-08-2007, 07:31 PM | #199 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
| Hustler issues
-------------------------------------------------------------------------------- I've been working on this thing for days can't figure it out why my axle is sitting sideways.. See if I can make this make sense. I put a 3mm screw in the rear shock mount hole. Measure from the end of the screw to the center of the upper link mount hole. do the same method of measuring. Driverside measures 3 1/4 passenger side measures 3 7/16. If you look at the chassis straight down from the top you can clearly see one link is clearly farther forward than the other. same measurement but from lower link mount holes to screws on shock mount plates driver side is 4 3/16 and passenger side is 4 3/8. Now measuring with the same bolton the rear shock mount on a flat surface fom the bottom on a flat surface the end of the screw measures 2 3/16 on driver side and the passenger is 2 5/16 so the screw plates are facing slightly different angles. I know a few of you guys don't like me or larry but for $329.00 this thing should line up perfect. On a super I can see it not being as big an issue but with such short links on a 2.2 I feel it is a big problem if suspension hinge points don't line up. Who should I speak to about this. John, ? Noel? No I am not trying to be picky. It's hard enough trying to make it work on wheely king axles as it is. |
09-08-2007, 07:41 PM | #200 | |
Thanks, John | |
