11-11-2007, 01:57 PM | #301 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Our ring and pinions are designed to work without any shims. But, Just like any gear-set 1:1 or R/C there are tolerances with not only the gears themsleves, but also the housings and bearings. Shimming, if neccesssary, to achieve optiumum gear mesh is always a good idea. The "Up" position on the C is stock. The "down" position brings the pinion more parrallel to the ground for improved drive line angle on scale builds or builds requiring less angle. | |
11-11-2007, 06:49 PM | #302 |
11-11-2007, 08:37 PM | #303 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
I'd say about 20 degree difference. Still pointing up ever so slightly.
11-11-2007, 08:46 PM | #304 |
| So it makes the pinion parallel to the ground, thank you. It would be nice if you made a set that splits the difference and gives a ten degree pinion tilt up for comp use running droop setup.
11-12-2007, 05:37 PM | #305 |
Rock Crawler Join Date: Jan 2006 Location: commerce twp.
any word yet on when the aluminum knuckles and other goods going to be back in stock for the ax10 im in a big need for these thanks.
11-13-2007, 06:42 AM | #306 |
Quarry Creeper Join Date: Oct 2005 Location: ELLENSBURG, WA
11-14-2007, 07:36 PM | #307 |
Back in stock fellas. Thanks for your patience!
11-15-2007, 05:22 AM | #308 |
11-15-2007, 09:07 PM | #309 |
Rock Crawler Join Date: Mar 2006 Location: Holiday, FL
When are the sinner series beadlock going to be out?
11-16-2007, 04:42 PM | #310 |
No release date as of now, but we hope to have them by next month.
11-17-2007, 06:28 AM | #311 |
Rock Stacker Join Date: Oct 2007 Location: somewhere
Not sure if this is the right place but what should I do to extend the WK into a trail truck?
11-17-2007, 11:40 AM | #312 | |
http://www.rccrawler.com/crawlerking1.html | |
11-17-2007, 12:54 PM | #313 |
I wanna be Dave Join Date: Jun 2005 Location: The bunker
| MIP CVD's and stainless ring and pinion
I am having a little trouble getting the cvd's and the ring and pinion to fit properly . I took a few pictures to show what i'm talking about. If i'm doing it wrong please set me straight. Thanks. The first picture shows how far the cvd sticks out from the end of the axle. This picture shows the the groove for the E-clip is on the outside of the bearing instead of the inside. Here it is with the bearing installed. The last picture is just a shot of the entire axle. The one side fits perfectly ,but the other seems to be off by the added thickness of the ring gear. Help...... |
11-17-2007, 11:02 PM | #314 |
You may have a defective R&P. PM me to sort this out. In the meantime you can try tapping it in with a hammer but you should wait if possible.
11-18-2007, 06:09 AM | #315 |
I'll wait. i don't wanna screw up the axles or ring. i'll pm you.
11-19-2007, 04:50 PM | #316 |
Rock Crawler Join Date: May 2004 Location: Calgary
I have a few quick questions: 1) Are you gonna be carrying the new RC4wd "Rock Stomper" tires? If so, any ETA on these? 2) When will you have more of the JP Clod knuckles with CVD ball bearings? 3) Are the ThunderTech CVD's a "Drop-in" upgrade for stock clod components, or do they require differnt knuckle bearings? Thanx. |
11-23-2007, 11:41 PM | #317 |
Rock Stacker Join Date: Sep 2007 Location: Wherever Uncle Sam tells me
| Well, I値l start with my question first. What springs should be or can be used on the 3.5 inch Traxxas Ultra Shocks? I知 looking at running them on my K2 to get a bit more travel. Suggestions and/or part numbers would be great. Now the suggestion, I know a lot of folks use the HPI stock car wheels on their scale builds as well as the Tamiya Hummer wheels. Is there any chance that you値l carry either of them, as well as other select 1.9 wheels for the scale builders? Thanks |
11-26-2007, 01:22 PM | #318 | |
Answered your questions in red: Quote:
11-26-2007, 01:27 PM | #319 | |
The Hpi stock car wheels should be up on the site within the week. | |
12-06-2007, 04:40 PM | #320 |
RCC Addict Join Date: Jun 2006 Location: Sin City
| Lost receipt
I need to get a copy of a receipt from Aug. 07. How do I go about it. Thanks,Steve
