04-27-2007, 06:15 PM | #181 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
dont forget the center pin
04-27-2007, 06:33 PM | #182 | |
Rock Crawler Join Date: Nov 2005 Location: Okinawa, Japan
Same thing for me... I was selling my Super when they showed up. I will be at the PO at 0700 when they open Then off to the CO GTG. I was hoping to have them installed tonight though... | |
04-27-2007, 06:53 PM | #183 |
Quarry Creeper Join Date: May 2006 Location: Oregon
Got mine today, thanks RCP! Now just gotta wait for those new ring and pinions so I can build the ultimate axle! |
04-27-2007, 07:48 PM | #184 |
I took work off today, and still missed the mailman! I knew I shouldn't have run out to get that mocha. Now I'm counting the hours until monday morning, 9:00am sharp. Everything will be fine, as long as I can keep my 9yr old daughter from breaking her axles at the ORCRC comp sunday. |
04-27-2007, 08:07 PM | #185 |
Rock Stacker Join Date: Feb 2007 Location: Aussie Crawlin Sin City
Got mine thanks RCP!
04-27-2007, 09:15 PM | #186 |
Pebble Pounder Join Date: Aug 2006 Location: Next door to Louisville, KY
Got them installed and I love the extra steering. A little grinding on the alum knuckles and it steers great. DE |
04-27-2007, 10:23 PM | #187 |
RCC Addict Join Date: Apr 2005 Location: Seattle
Mine arrived today, and are installed. The steering is fantastic, even without making ANY changes to my setup... can't wait to getting around to resetting the EPA. One question. I am running RC4WD beadlocks, and the spacer with the small hex setup does not work with them, the whole assembly locks up tight and the wheel won't spin. I got it work by using the larger hex (which I didn't want to do), but can you offer any advice on this? |
04-27-2007, 10:58 PM | #188 |
Quarry Creeper Join Date: Jul 2004 Location: 808
Got mine and installed today. They work great with the Axial 2.2s. Just a note to everyone that has to shave their aluminum knuckles, aluminum dust is bad to breath in...I remembered that while on the second knuckle and right about when I was done with it... |
04-27-2007, 11:08 PM | #189 |
Rock Crawler Join Date: Nov 2005 Location: Livermore
| Rcp Rocks
Received my CVD'S today What can I say, the fit and finsh is GREAT. Can't wait to run them in the comp on Sunday, the added steering and strength I know I am going to love. Thanks RCP for the GREAT Products and Service |
04-27-2007, 11:14 PM | #190 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Got mine installed tonight...I guess this morning. Another great product from RCP. Thanks Brian. John |
04-28-2007, 12:43 AM | #191 |
I don't know if it is just the beadlocks, but more likely all RC4WD wheels, but the thin hex in the CVD kit is so thin it drops down inside the hex hole in the wheel. The wheel is able to tighten down on the knuckle when the bolt is tightened down. This locks up the wheel so it won't spin. Quick fix... A minute with a Dremel cut-off wheel and I shaved down the hex hole on the wheels a bit, now everything moves and clears perfectly. |
04-28-2007, 12:50 AM | #192 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
04-28-2007, 01:13 AM | #193 |
Mixing different manufacturers parts almost always asks for mods, here is what I am talking about. Fat Rocks and run2jeepn knuckles with RCP CVD's and RC4WD wheels. This first pic shows the wide hex installed. No problems at all, I just like my truck narrow. Here is with the thin hex installed. The wheel hex hole completely swallows it and you can see the wheel is pressed into the knuckle, locking everything up. After I figured out what was happening, I ground down the lip around the hex hole in the wheel, now it works as intended. This is the narrow hex, with the wheel modified. Hope this helps someone! |
04-28-2007, 01:34 AM | #194 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
You beat me to it J, here it is anyway 1 solution is the same the other is a simple washer hope it helps, Devlin Mine are insatalled and I figured out the problem with the smaller hex. You need to face about a 1/16th" off of the hex on the wheel or put a washer between the small hex and the wheel. The milled hex on the wheel is deeper than the small hex spacer and causes binding on between the wheel and the hub. | |
04-28-2007, 02:59 AM | #195 |
yeah, i would have gone with the washer over cutting down on some 100+ wheels. the washer is easily reversable |
04-28-2007, 03:13 AM | #196 |
Ah, no biggie. I didn't have to grind off much, and they will still work on any other rig.
04-28-2007, 03:18 AM | #197 |
Quarry Creeper Join Date: Nov 2005 Location: ov'a hea
sweet!!!!! they came today. can't wait till i get the rest of my stuff so i can start my build. |
04-28-2007, 03:40 AM | #198 |
| ok, yeah, that was my concern. awhile ago i picked up some tamiya alu clamp type hubs new and dirt cheap, when i got em they were thinner than a typical hub and i ended up just popping some 1mm washer/shims on each then the tire and it fit fine.
04-28-2007, 07:56 AM | #199 |
well i got em. they look nice and beefy, so much nicer to see them in my hands rather than in pics! and in the bag they'll stay until the SS R&P's are available. |
04-28-2007, 09:43 AM | #200 |
I would like to buy some spare parts for these. Any thoughts on if you might offer that? I would like: New joint pins (incase I lose or break one) extra bearings (for spares) Maybe the drive pins as well Please let me kow if you will be offering any parts. Thanks DE |
