09-26-2010, 09:53 PM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: Federal Way
| Full Droop questions
I have decided to try full droop on my RS-10 to see if I like it. Plus my springs rub the motors. I have mounted my shocks upside down for the weight benefit and now I would like some advice on both oil weight and hole size on the little plunger disk inside the shock. Also any other tips you think I might like. I am running 15wt oil right now. The truck stays down when I push it down but also stays up when I lift it up. Is this normal? One other thing is my shocks leak, any quick cheap or free tips to stop the leaks? Thanks for your help |
09-27-2010, 02:39 PM | #2 |
Pebble Pounder Join Date: Apr 2010 Location: Brighton, MI
It should try to return to one position, maybe your springs are too soft. I ran 100wt oil for awhile and liked the predictability but seems like the 60wt is a good balance point. Also, make sure to use silicone oil, not motor/gear oil to avoid leaks. Also take a good look at where your top cap threads to you shock body as they always seem to want to cross thread and then leak. Good luck!
09-28-2010, 07:44 PM | #3 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
In a full droop setup, the crawler should stay fully compressed and the shocks extend if the wheels drop. I'm betting your springs are too soft...try changing that up a bit and mess with the shock oil. When I ran full droop, I ran medium tension springs and 100wt oil and the setup worked well for my rocks, but I ultimately went back to sprung shocks.
