RCCrawler Forums
RCCrawler Forums (http://www.rccrawler.com/forum/)
-   Redcat Crawlers (http://www.rccrawler.com/forum/redcat-crawlers/)
-   -   blinds ebay rs10 build (http://www.rccrawler.com/forum/redcat-crawlers/259071-blinds-ebay-rs10-build.html)
blindsnyper 07-12-2010 02:06 AM
(remaking an "intro")
i have decidede to make this an ebay build.
so far i have weighted the wheels, cut out the small treads on the tires, lower the body and destroyed the original servos.
i just ordered 2 tower pro mg945 servos. next on the list are a home made aluminum wing eiminator and a bec, any sugggestions for one??? on ebay of course (less than $15).
also can the original lower links be bent???
http://i230.photobucket.com/albums/e...r/P6260295.jpg
jsowens 07-12-2010 07:37 AM
Unfortunately you're not gonna find a decent BEC on ebay for under $15. The 2 most common ones that people use, and arguably the best, are the castle creations BEC (which is around $20 and you also have to have the castle link cable, which is sold seperately, to program it to the voltage you desire) and the rc4wd turbo BEC, which is around $20 and comes pre-programmed to a good voltage. Personally, I would suggest the rc4wd BEC simply because you don't need an additional cable, but I've never seen one on ebay. Good luck.
jacks766 07-12-2010 01:07 PM
yes, the lower links can be bent....
Also zno-rc has a BEC for under $20....
http://www.zno-rc.com/pages/products/RW0301_hv_bec.html
jsowens 07-12-2010 05:30 PM
Yep, that's the one I was rambling about. I run one on my rig and it does well. I've not seen them on ebay, though...which is what the original poster wanted.
Dabandit1 07-13-2010 07:56 AM
90% of stuff on ebay can be had for the same price or cheaper on ckrc,biggest killer will be the shipping costs buying 1 item at a time on ebay as opposed to 1 or 2 bigger orders from a decent vendor......I've spent hundreds in shipping on ebay
crawlhog 07-13-2010 04:00 PM
very true but CKRC also rapes you on shipping they start at $15.00 for shipping even if its a small pinion i personally will never buy from them again because of that:flipoff:
blindsnyper 07-15-2010 04:10 AM
i think instead of getting only a bec, i will get this when funds allow...
http://cgi.ebay.com/ws/eBayISAPI.dll...%3DI%26otn%3D2
blindsnyper 07-17-2010 05:55 PM
today i ordered softer springs, and rod ends.
i also bent the oem lowers, cut off about 3/4" from the oem springs (about 1/2 droop), made a skid plate out of a rockstar cola can and made wing eliminators. now waiting for servos and rod ends to play more.
blindsnyper 07-29-2010 04:28 AM
i just ordered the outcry esc and some rover white dots, both off ebay :)
soon i will be getting some bane bots (havent decided between 380s and 390s), i also need a better battery soon....in due time
nwcrawler 07-29-2010 11:42 AM
i would go with the 540 swap. rc4wd.com has some good motors for 9.99 on there and you can drill out your stock pinions to fit the 540 shaft.
8)
DinoCrawler 07-29-2010 12:23 PM
8)
If you decide to go with motors with 1/8" shafts ZNO-RC has 8 tooth and 10 tooth pinions already drilled. They also stock the ESC. But to do this you would have to break your "Ebay" rule. :mrgreen:
blindsnyper 07-30-2010 10:01 PM
so i figured i would throw some money at my LHS and get a battery, although i did get a battery i will never give them a dime of my money again. they were all douches (yes, it took 3 people to sell me a battery) and i found out that they flat lied to me when i was in last to get a charger (i was told they quit carrieing the prophet plus and replaced it with the onxy whatever, when they were acctually just sold out).
anyways. i got a dtx 7.2v 3600mah stick battery, a major improvment from the original battery.
thinking about locking out the rear and saving the servo for when the front one dies, but i want to get some more practice in before then.
blindsnyper 08-04-2010 09:32 PM
today i locked out the rear,and sheared the pin in the spur gear housing on the rear, so i ordered hardened ones.
with the new esc the rig will run fine for about 5-10 min then it acts like it has a low battery when going forward (reverse is normal), but if i shut it off then turn it back on it goes back to normal. any idea what this could be? i thought maybe the esc was getting hot so i cut a hole in the body above the fan because of how close the bosy is to it. could it be bad motor(s)?
redcatguy 08-07-2010 04:55 PM
what kind of esc are u running and did u get it wet. what batteries are u running do u run them totally dead. if u have lipo batts that is not good but it is good on the nimh batts.
muddywaters7 08-08-2010 12:34 AM
Lookin good. Did you take the tire foams out? they look super soft in that picture. Which stock servo died first? front or rear?
blindsnyper 08-08-2010 04:35 PM
i got the outcry duak motor esc, and i didnt get it wet. i have a 7.2v 3600mah nimh stick battery that i have only ran enough the run dead once. the rig is apart more than it is crawling.
blindsnyper 08-09-2010 05:06 PM
i also just put an 8t pinion on the rear to HELP with clod stall. i think i am setup pretty good for now.
blindsnyper 08-17-2010 01:02 AM
i managed to drop my radio directly on the wheel, so now it doesnt work properly. luckily they are cheap, down for at least 2 weeks :(
DinoCrawler 08-17-2010 09:23 AM
Sounds like a good time to upgrade the radio.
blindsnyper 08-17-2010 02:19 PM
i would but i decided i was done spending money on it. and i am ok with the original one. it just sucks that it is unable to run, again.
