540's and pinion poll (kinda) Anyone using 540's in there dime please reply with what pinon gear size you are using. .. Thanks !!"thumbsup" |
when running 540's you need to run how ever many teeth pinion you want but needto make sure its a metric 48 pitch also hope that helps..... hows this a poll?:lmao: |
lets Call it Pinion Q&A.. :mrgreen: |
im running novak 45's with 8t front and rear works out great for me. no clod stall at all. |
Thanks Talon"thumbsup" |
i run 45t, with soon to be 10tooth pinions as soon as i put them in. i also ran 16tooth and crazy fast. you want a rock racer this is the way to go. had the same stall as my 390 12volt banebots. did 8 tooth as well, and no stall at all on any incline. feathering the throttle slightly was the only time it stalled. going the tens cause i want a little stall. i believe the smallest metric pinion is 12t by Robinson racing. berg pinions will work as well. more of a variety of sizes. |
ThanX again every1"thumbsup" |
