09-29-2010, 10:28 PM | #1 |
Newbie Join Date: Apr 2009 Location: phx
| steering servo....
So I destroyed the stock servos on my crawler the other day. Ive been looking at replacement ones but got confused, with protectors and digital programing. So since Im on a buget and I use the stock esc and controler, can some one suggest a new steering servo? I look at ZNO-RC but hes sold out of his 34$ one. Thats kinda in my budget. Ive moddified my steering to turn better, grinded the axles like the axial guys do. Any help would be greatly appreciated. Geoff L.
09-30-2010, 03:41 AM | #2 |
Rock Stacker Join Date: Jun 2010 Location: oregon
hitec hs645mg is good starting point until you can afford better.
09-30-2010, 06:51 AM | #3 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
RC4WD mayhem servo would be in your budget. That, or the 645mg from hitec...either one would be a good choice.
09-30-2010, 09:01 AM | #4 |
Thanks guys. Ill post pics of it and all the little tricks Ive got on it when i get it back together.
09-30-2010, 09:06 AM | #5 |
Rock Stacker Join Date: Sep 2010 Location: Bradford,Ontario.. Canada
I have seen a few of these being used locally and seem to be holding up http://www.hobbyking.com/hobbyking/s.../_.13sec_/_52g |
09-30-2010, 09:52 AM | #6 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
The rc4wd is a great servo if you are on a budget . Its much better than the 645 imo . I use them on all my rigs except when Im competing . They have been very reliable and way stronger than the stock rs-10 .
10-01-2010, 12:35 PM | #7 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
We also offer a budget metal gear servo with over 200 in-oz (15kg) of torque for $22. For comparison, the stock RS10 servos are a 6kg servo with plastic gears. http://www.crawfordperformanceengine...ervo-p-18.html |
10-01-2010, 03:56 PM | #8 |
Pebble Pounder Join Date: Sep 2010 Location: Brussels/Belgium
Here is the one I've found: Power HD: "High-Torque 60G Servo 1501MG Metal Gear 17KG": Power HD web site: http://chd.hk/ And the specs: Dimensions Size: 40.7 x 20.5 x 39.5 mm Weight: 60 g General specifications Digital?: N Speed @ 6V: 0.14 sec/60° Stall torque @ 6V: 17 kg·cm Speed @ 4.8V: 0.16 sec/60° Stall torque @ 4.8V: 15.5 kg·cm Lead length: 11 in Hardware included?: Y They are analog servo with metal gear and can be find at around 18 USd depending on the shop. They also are mentioned on this website in the "most popular servo" section: http://www.servodatabase.com/ I should have mines pretty soon... Last edited by Big Pitt; 10-01-2010 at 03:58 PM. |
10-02-2010, 10:11 PM | #9 |
Pebble Pounder Join Date: Apr 2010 Location: Brighton, MI
RC4WD servo was good for $30. Mine broke the face plate after a month but the people at rc4wd hooked me up with a warranty replacement. The gears and electronics were good though.
