Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: steering servo....
Old 09-29-2010, 10:28 PM   #1
Default steering servo....
So I destroyed the stock servos on my crawler the other day. Ive been looking at replacement ones but got confused, with protectors and digital programing. So since Im on a buget and I use the stock esc and controler, can some one suggest a new steering servo? I look at ZNO-RC but hes sold out of his 34$ one. Thats kinda in my budget. Ive moddified my steering to turn better, grinded the axles like the axial guys do. Any help would be greatly appreciated. Geoff L.
showboat is offline   Reply With Quote
Old 09-30-2010, 03:41 AM   #2
hitec hs645mg is good starting point until you can afford better.
blindsnyper is offline   Reply With Quote
Old 09-30-2010, 06:51 AM   #3
RC4WD mayhem servo would be in your budget. That, or the 645mg from hitec...either one would be a good choice.
jsowens is offline   Reply With Quote
Old 09-30-2010, 09:01 AM   #4
Thanks guys. Ill post pics of it and all the little tricks Ive got on it when i get it back together.
Old 09-30-2010, 09:06 AM   #5
I have seen a few of these being used locally and seem to be holding up
http://www.hobbyking.com/hobbyking/s.../_.13sec_/_52g
michael_lambert is offline   Reply With Quote
Old 09-30-2010, 09:52 AM   #6
The rc4wd is a great servo if you are on a budget . Its much better than the 645 imo . I use them on all my rigs except when Im competing . They have been very reliable and way stronger than the stock rs-10 .
rc_pimp is offline   Reply With Quote
Old 10-01-2010, 12:35 PM   #7
We also offer a budget metal gear servo with over 200 in-oz (15kg) of torque for $22. For comparison, the stock RS10 servos are a 6kg servo with plastic gears.
http://www.crawfordperformanceengine...ervo-p-18.html
CPE MT is offline   Reply With Quote
Old 10-01-2010, 03:56 PM   #8
Here is the one I've found:
Power HD: "High-Torque 60G Servo 1501MG Metal Gear 17KG":
Power HD web site:
http://chd.hk/
And the specs:
Dimensions
Size: 40.7 x 20.5 x 39.5 mm
Weight: 60 g
General specifications
Digital?: N
Speed @ 6V: 0.14 sec/60°
Stall torque @ 6V: 17 kg·cm
Speed @ 4.8V: 0.16 sec/60°
Stall torque @ 4.8V: 15.5 kg·cm
Lead length: 11 in
Hardware included?: Y
They are analog servo with metal gear and can be find at around 18 USd depending on the shop.
They also are mentioned on this website in the "most popular servo" section:
http://www.servodatabase.com/
I should have mines pretty soon...
Big Pitt is offline   Reply With Quote
Old 10-02-2010, 10:11 PM   #9
RC4WD servo was good for $30. Mine broke the face plate after a month but the people at rc4wd hooked me up with a warranty replacement. The gears and electronics were good though.
dudegetabike is offline   Reply With Quote
