01-09-2011, 09:56 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: San Anselmo, Ca
| Bent link ?
I just up graded to the axial 101mm 30* bent links. How do you keep the links from rocking side to side? I have a XT and I'm still using the factory shocks and mounts. When the links rocks to one side it interferes with the motor i just want to reduce the amount of side to side movement.
01-10-2011, 04:10 AM | #2 |
Newbie Join Date: Dec 2010 Location: Flour Bluff
I put little o-rings in between the lower links and the chassis, to limit the roll of the links,keeping the shock mounts vertical instead of rolling out towards the tire. It helps quite a bit but there is still a bit of rub. Next is a narrowed chassis which should clear everything up.
