06-11-2011, 10:17 AM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| axial wheel hubs
Does anyone know if these fit redcat axles? Are the dogbones compatible? I was hoping to run axial alloy steering knuckles as well. can I use the redcat ball bearings? or are the axial ball bearings a different size on the hubs? http://www.integy.com/st_prod.html?p...84&p_catid=124 |
06-11-2011, 11:35 AM | #2 |
all the parts you mentioned will work, i used them on mine with no problems |
06-11-2011, 11:36 AM | #3 |
Pebble Pounder Join Date: May 2011 Location: Vacaville
Not sure. I tried to run some XR-10 wheel on stock hubs and they rubbed Uber bad with rovers. Justin |
06-11-2011, 03:25 PM | #4 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Running HR axial steering knuckles on mine and the stock bearings from the plastic RS10 knuckles fit fine.
06-13-2011, 12:14 AM | #5 |
Thanks! I'll order some of these guys up. Needed to replace a hub anyways. the cup is worn, causing that dogbone to spit out. a fresh one otta fix it. We gotta work on some proper CV's for these things. wish I knew how to weld things that small. |
06-14-2011, 11:54 AM | #6 |
Newbie Join Date: Jun 2011 Location: UK
For fine welding see this pdf: http://www.oxyturbo.it/pdf/EN_welding.pdf. This is for an Italian range of oxy-hydrocarbon gas welding sets. See the pages on the Turboset 90-110. I have the 110 set and it offers microjets for really fine work as small as jewellery (UK spelling). These are really just trimmed hypodermic needles but they do work. Obviously an existing skill at gas welding is a prerequisite but it is a cheap and effective way of doing close to oxy-acetylene welding at much less cost and hazard than acetylene kits. Don't know if it would be available to you in Canada but hope you will find the info of interest. Got my set through eBay.co.uk but can't see similar on eBay.com for you.
07-02-2011, 06:35 AM | #7 |
Newbie Join Date: Jun 2011 Location: winchester
Installed some axial aluminum c hubs and high steer knuckles. They turn very easy not on the axle. When i secure them to the axle they become very tight and make a grinding sound in the ring and pinion gear. Does anyone have any experience with this?
07-03-2011, 07:24 AM | #8 | |
But onto your question...take a very close look at everything you changed. Do the wheels contact the knuckles at all? Try removing your wheels and see if you still get the noise. Also look at the screws you attaches the steering knuckles with. Are they long enough to where they actually touch the cup where the dogbone sits? | |
07-04-2011, 01:01 AM | #9 |
I noticed my 12mm hexes would cause grinding if they were too tight up against the steering knuckles. I had to just space them out a mm or so. It's worth checking. |
07-04-2011, 11:45 AM | #10 | |
07-04-2011, 09:27 PM | #11 |
07-06-2011, 01:31 AM | #12 |
So I got the integy steering knuckles, and the integy 15mm extended hubs. I installed them using the rs10 bearings, and there seems to be a lot of play between the hubs and the bearings. Do I need to change to axial bearings?
07-06-2011, 06:50 AM | #13 |
| Is there enough room for a small washer? On mine, I had some play and just slid a small/thin washer between the hub and bearing and it fixed it.
07-06-2011, 06:23 PM | #14 |
| Yeah I think I see that now. either that or drill out the extension to fit farther on the hub. Not much consistency between each extension eh? A mm or so difference on each one.
