09-10-2011, 03:20 PM | #1 |
Newbie Join Date: Sep 2011 Location: SLO
| Axle tech
Was just wondering what would be the cause of rear wheels spinning off the ground but not when a load is applied. I have taken the axle apart but cant get the spur gear apart
09-10-2011, 04:05 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Plenty of threads in here about this exact problem. Most likely the pin inside your spur assembly has broken. Try getting the spur apart...there are 4 screws on the spur assembly itself, and on each outdrive cup there is a long set screw. Remove all of that and it should pull apart.
09-10-2011, 06:07 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver Wa, USA
I have a set of harden pins from ZNO (NIP) I'll send ya for $5. Stamp is on me (lol) Smitty |
09-10-2011, 08:44 PM | #4 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
| nails
Wont a finishing nail work just as well? Although 5$ for pins is a steal
09-11-2011, 06:38 AM | #5 |
09-11-2011, 07:30 AM | #6 |
| rest of inside
Dont you want it somewhat like the old pin, putting a hardened one in just means u need change the rest of it, the pin is designed to break instead of the gears right?
09-11-2011, 08:52 AM | #7 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
09-11-2011, 11:48 AM | #8 |
Thanks guys for the info. I got the spur gear apart and used a drill bit cut down to fit was all I had. Guess i should get some metal gears to back it uo
