11-17-2011, 09:46 PM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: Paragould
| axle stubs?
what other axle stubs will fit the rs-10 ? i broke mine on a bad fall and while i am at it what is the pinion size that comes with the rs-10? 8 or 10? i want to switch one and see if it helps with clod stall some. |
11-18-2011, 07:53 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Axial axle stubs should fit. I can do some measuring tonight if you'd like. The original RS10 came with 10t pinions and the XT comes with 8t.
11-18-2011, 09:11 AM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: SHADYSIDE
Ibroke one of mine also, installed some ax10 used ones I had , running them in the front, fit perfect.
11-18-2011, 09:54 AM | #4 |
| thanks for the response guys now i believe i have the OG rs-10 but just in case. is there a way to tell by looking at the axles or anything? and axial stubs would be great i can order them from RPP with some other stuff i wanted and not have 2 shipping charges |
11-18-2011, 08:54 PM | #5 |
The original RS10 didn't come 4-linked and had those ugly wing things over each axle. The XT came stock with a 4 link mount on the axle. That's the best way to tell, unless you bought it used and already 4 linked. Either way, the easiest way to find out how many teeth your pinions are is to take off the little cover that fits over top of the pinion, then count the teeth.
11-18-2011, 09:48 PM | #6 |
thanks ya i had that fugly wing thing on there. i ordered 8t and new stubs today thanks guys love my rs10 axles |
