11-19-2011, 02:54 PM | #1 |
Rock Stacker Join Date: Nov 2011 Location: Spokane
| Flysky gt3b with stock ESC
I was wondering if the flysky gt3b will work the stock ESC on the rockslide RS10xt out of the box? or will I have to change the esc out with another one? Thanks |
11-19-2011, 03:26 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
What ESC you have doesn't determine what radio you can use. Technically, you could use just about any radio out there with the stock ESC. So in short, yes...it will work. I ran that exact setup before I got a new ESC.
11-19-2011, 05:24 PM | #3 |
So one more thing. Do I need another powerpack in order to use the RX? New to R/C sorry for the newbie questions.
11-19-2011, 05:59 PM | #4 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| no ihave the same controler just unplug the old rx and plug the new rx in add batteries to both tx and rx turn them on and crawl yes its that easy i promise |
11-19-2011, 06:55 PM | #5 |
Thanks.
11-20-2011, 07:06 AM | #6 |
Pebble Pounder Join Date: Sep 2011 Location: perth wa
yes mate it will work i use one on my redcat |
11-20-2011, 08:59 AM | #7 |
Quarry Creeper Join Date: Apr 2008 Location: SHADYSIDE
Thats the same controller iam using with my cat also, very easy to use, not a single problem, ran mine with the stock esc then installed a new outcry esc, still using same radio. |
11-26-2011, 09:12 PM | #8 |
Rock Stacker Join Date: Mar 2010 Location: San Antonio
Guess I will ask too, does this one work with dual steering?
11-27-2011, 04:08 AM | #9 |
| nope, at least not straight out of the box, the third channel switch is not a three position switch but there is some info on here on how to "hack it" and make it a 6 channel remote and then well, u know it does anything u need it to then |
11-27-2011, 07:51 AM | #10 |
If you're not up for modding one of the radios yourself, losikid here on the forum will hack one for you. Then you can use rear steering with it. Products - OverkillRC |
11-27-2011, 09:07 AM | #11 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
I've got this same setup on my Redcat. I use the 3rd chan. for the rear steer. It only locks it down in one direction, but you can adapt to it pretty quick.
11-27-2011, 09:45 AM | #12 |
| i assume u have it centered in one position and then it only turns either left or right whichever way u have it set?
11-28-2011, 08:23 AM | #13 |
11-29-2011, 06:28 AM | #14 |
Newbie Join Date: Jan 2011 Location: Sandwich
11-29-2011, 06:40 AM | #15 |
By getting the 3 position adapter, would that fix the issue. Or do you still have to have the firmware update Products - OverkillRC |
11-29-2011, 07:09 AM | #16 |
| The point of having a 3rd channel is to run additional servos and accessories...such as rear steer and dig. Without the 3rd channel, it's not possible.
11-29-2011, 07:51 AM | #17 |
11-29-2011, 08:34 AM | #18 |
| I under stand that the 3rd channel is needed to run rear steer but with out the 3 position switch how is possible to use the 3rd channel as the rear steer?
11-29-2011, 09:09 AM | #19 |
| If you invest in a hacked gt3b or hack it yourself, if I'm not mistaken the 3rd channel button can be set up as a 3 position. So you just press the button to cycle through the positions. Losikid would be the best person to ask that since he developed the hack kit. I don't know that rear steer is possible on the stock gt3b 3rd channel button.
11-29-2011, 09:20 AM | #20 |
Ya I started reading the novel of 40 sheets for losikid hacked gt3b. I'll have to get a kit with the next paycheck and cross my fingers and see if I'm a decent soldier. thanks |
