Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: HD's Redcat "comp" Redo "Lady Luck"
Old 01-23-2012, 09:11 AM   #1
Fan of wheelspeed
Talking HD's Redcat "comp" Redo "Lady Luck"
I had named my tuber "lady Luck" but decided to do a identity swap, so decided to take apart my Redcat Jeep to build a all out crawler. I started with my Redcat axles with the stock 390 motors and a Axial XR10 chassis. I stole the S&S high clearance delrin links from my tuber build and paired them up with some unknown delrin front links.
First step was a BTA mod. I drilled new holes in the stock servo bracket.
I had to drop the linkages below the front links and work out a short small link to connect my Robotronics servo horn to my Hitech servo.
At this point, I was trying to figure out my link setup.
I think I got at this point.
130mm rear shocks???
I got my beadlocks done. Painted the outer rings with Candy red paint, and mounted my HB white dot Rovers on these AXial beadlocks. 4oz weight in each front and 2oz on each read wheel.
From this poiint all I have left to do is mount up my shocks and instal my electronics. The shocks have been a royal pain, I'm having to experiment back and forth with em. But I'll get them figured out.
Any input or advise?
Hoosierdady is offline   Reply With Quote
Old 01-23-2012, 09:25 AM   #2
Default Re: HD's Redcat "comp" Redo "Lady Luck"
Wow mate keep us posted
Ps it's sad to see the jeep go :(
jesseRS10comp is offline   Reply With Quote
Old 01-23-2012, 09:28 AM   #3
Lookin good I haven't seen anyone use that chassis yet and I like the delrin links. How high are you gonna have the Bottom of your shassis for clearance. I am curious cause I am finishing a similar deal and I got mine at 3 ish inches and I am wonderinf it its too low. I just don't wanna monster truck it. Also which body are you going to use?
Lookin' good!
Romad is offline   Reply With Quote
Old 01-23-2012, 09:32 AM   #4
3 inches is the norm mate so don't worry
Old 01-23-2012, 10:31 AM   #5
Lookin good! I have seen other guys run the XR chassis apparently with really good results (not to mention they look downright sexy! )
The Jackalope is offline   Reply With Quote
Old 01-23-2012, 11:49 AM   #6
Fan of wheelspeed
Yup, about 3 inches. I forgot to add the pic of the wheels...
The Jeep chassis is gonna set on the bench. I may end up rebuilding the Jeep into a full on scaler with this Scorpion I have coming in, not sure yet. Depends on if my daughter decides to get into crawling or not I suppose. I traded to get the Axial for her, hopefully she'll appreciate it.
As far as body goes, I'm going to use a Axial hardline body. Everything is going to be poker themed if you couldnt tell from the wheels, its all about a lil luck getting it up this mountain at my buddies house.
Old 01-23-2012, 12:34 PM   #7
where did you get those cool looking links from ?
screwed is offline   Reply With Quote
Old 01-23-2012, 01:11 PM   #8
Fan of wheelspeed
I bought the links off here. Seller said they were SS links. As for the front links, I have no clue who made em. I bought them off here as well.
Old 01-23-2012, 06:18 PM   #9
what rims are those mate ?
awesome build
Old 01-26-2012, 09:20 AM   #10
Fan of wheelspeed
Well, here she is. I'm still waiting on my body to get here for it. I'm going with the Axial Hardline shell. Here are some are some pics.
I changed out the servo to a Towerpro and went back to the Robottonics servo horn. The plastic one was shorter and therefor killed my turning radius.
Bottom view:
Balancing act:
Great ground clearance. Almost enought to stand the can up undernieth. The articlulationn seems to be spot on. Its raining now, so I'll have to try it out another time.
Old 01-26-2012, 09:41 AM   #11
well HD, icommented on this build already but i guess someone didn't like the comment i made? let's try again and see? it looks good-just alot like my badd bug except with bought parts/pieces-it'll perform great! trust me
FATBOYrs10 is offline   Reply With Quote
Old 01-26-2012, 10:06 AM   #12
Fan of wheelspeed
nah, rcc went down so they had to restore and alot of posts were lost.
Old 01-31-2012, 03:54 PM   #13
The links came from a bjv4 kit I bought very easy to duplicate.
Awesome build looks like I need to drive down and check it out
foratm is offline   Reply With Quote
Old 02-01-2012, 07:51 AM   #14
Fan of wheelspeed
come on down then. I've got a few places around here to crawl. Still no body pics. The tape I used for window masking left residue so I couldnt paint the windows last night.
Old 02-02-2012, 12:45 PM   #15
For sure we will have to break out the scale and comp crawlers.
Old 02-02-2012, 12:48 PM   #16
Fan of wheelspeed
I've got a nice scale build comin up soon.
Old 02-02-2012, 03:04 PM   #17
Fan of wheelspeed
I picked up a basher body from foratm. Used some dot4 to strip it and painted her up black with red windows.
I've picked up a new one that will be nice. Got some good ideas in mind for the theme.
Old 02-03-2012, 07:43 AM   #18
Looks sweet and very capable too.
Awesome build.
Im foratm and I approve this build.
Old 02-03-2012, 07:55 AM   #19
Fan of wheelspeed
Awesome build.
Ty sir. I've got a Rubi-Wraith build coming soon. Trying to hunt down a b/l setup for it now.
Old 02-03-2012, 08:54 AM   #20
Looks great. That forth photo is wallpaper material.
CAIRN is offline   Reply With Quote
HD's Redcat "comp" Redo "Lady Luck" - Similar Threads
HD's "Lady Luck" Mutt crawler Hoosierdady Venom Creeper 24 01-30-2012 08:54 AM
"Victim" or "V2" a "Country Boy Customs" class 3 Mighty1 2.2 Scale Rigs 10 05-06-2011 10:56 PM
"brushless review "ccmicro pro" vs "novak mong". ROLANDROCKSHOP Losi Mini-Rock Crawler 22 11-15-2009 08:27 PM
