02-13-2012, 05:44 PM | #21 | |
Newbie Join Date: Jan 2012 Location: Up north, eh
| Re: BRAINSTORM; Moving Those Motors
the XR10 is far from perfect so we'd be doing the same to that too lol. + modding these are 1/2 the fun! Quote:
02-14-2012, 01:36 AM | #22 | |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Re: BRAINSTORM; Moving Those Motors Quote:
The Jury is still out on whether a brushless motor is better than a brushed motor in Rockcrawling. They are bred for speed. I would test it out, but it's a bit expensive for trial-and-error in my books. If YOU want to fork out the $$, by all means. and document it well for the rest of us. here's that build thread; http://www.rccrawler.com/forum/redca...hless-mod.html | |
02-14-2012, 04:12 AM | #23 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
How about a change in motors? Take a look at this: They use these motors: HobbyKing R/C Hobby Store : A28L brushless Outrunner 920kv Yes, they are brushless and they use some cheap double esc. It can crawl without any problem: Nuevo XRS 10 (1).mpg - YouTube I might try this when I rebuild my rs10... The main problem with this car, for me, is the lack of cvd's for some good stearing... |
02-14-2012, 06:23 PM | #24 | |
02-14-2012, 06:42 PM | #25 |
Rock Stacker Join Date: Aug 2011 Location: canada
that looks like a nice clean install. i think i might go that way, when the time comes.
02-14-2012, 06:53 PM | #26 |
i had a look through hobby king site and theres no 48pitch 3mm shaft pinions listed. are the 48p pinions hard to find or something?
02-14-2012, 07:48 PM | #27 |
Pebble Pounder Join Date: Oct 2011 Location: Exeter Ontario
so that tiny motor would output the same torque as z decent 540? edit: 50 bucks shipped and i could do dual esc brushless in a VERY fitable package. Last edited by JKMotorsports; 02-14-2012 at 08:03 PM. |
02-15-2012, 04:03 PM | #28 |
I got looking into this myself. What if we took the axle tubes and cut them up to use only the part that mates to the center section and then make a piece of aluminum tube glued and riveted to the plastic. Then you could cut them to a custom offset and then use aftermarket Axial c's and hubs? I'd trh it if I had a spare set of axles. |
02-15-2012, 09:55 PM | #29 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
just my other 2cents, yall ever heard the phrase-pissin in the wind? you're wasting your time. no one would buy it even it worked! these are $150 crawlers, i could only imagine what it would cost if it did work? the only mod i feel that needs to have this much thought put in it for the rs10 would be some CVD's! just my opinion, but i've been called an A-hole before.
02-16-2012, 02:51 PM | #30 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
I admit, I'm curious about what kind of mods you guys ultimately come up with to fix this problem. Realistically, I think it's just going to be DIY mods and never anything mass produced, though. The top half of the gearbox is removable...so in theory it's possible to make an aftermarket offset gearbox top half, which would likely require the gears to be reconfigured or remade for this gearbox, but it's not outlandish. The issue with this is the cost of the parts. On the XR10, the VP aluminum gearboxes are $40 per axle, so right there is over half of what the RS10 cost to begin with. The RS10 has a pretty small following overall, so the likelihood of a part like this coming into existence is very slim. Hacking up an extra axle housing or adding axle tubes to this isn't a bad idea and would probably work if done well, but for the average RS10 buyer who expects to simply buy things and bolt them on, it's not gonna be possible. Turning the RS10 into a set of shafty axles isn't the best solution either. For one, there would be little market for such a part, secondly the cost wouldn't be cheap, and thirdly a set of shafty axles are dirt cheap these days so why wouldn't you just buy a set of those instead of the necessary part (if it existed) to turn a RS10 into a shafty? Not to mention turning them into a shafty would require you to buy a transmission, chassis, and driveshafts. If you bought all that, you could just buy a nice, used ax10 to begin with. Those of you guys who plan on trying to come up with a mod to shift the gearbox over...good luck to you. Hopefully you'll come up with something awesome. For everyone else who wants more power, I suggest finding a motor that works for you (a shorter can 540, 380, brushless, whatever), try 3s lipos or hell, buy an ESC that can handle 4s lipos, and tinker with your shock and link setups so that they clear bigger motors. The big question you need to ask yourself is what do you need more...bent links or bigger motors? I know the bent links tend to not work well with 540's. Another option is to try shocks that have mini-t springs installed on them so that gives you an extra millimeter or 2 of clearance. Cross your fingers that the folks who make aftermarket RS10 parts make things we can use and not piss off our wives, girlfriends, and/or bank accounts by buying them, such as CVD's. Last edited by jsowens; 02-16-2012 at 02:53 PM. |
02-16-2012, 04:16 PM | #31 |
4s lipo. hmmmmm . I do believe my escs are rated at 14+ volts! BUT I would destroy all other drivetrain parts! |
02-28-2012, 10:46 PM | #32 |
| Re: how long are your motors?
Holmes Hobbies 540 TorqueMaster Sport is 52mm or 2, 1/16 inches from mounting face to endbell bearing. I'm thinking about trying these without the "Big Boy plate". I would gain 7mm. Barely over a 1/4 inch from my current setup. But it would sure tuck the wires out of the way! |
02-29-2012, 02:55 PM | #33 | |
Rock Stacker Join Date: Nov 2010 Location: Silicon Valley
For the right smooth it is important to choose an outrunner with 12 stator arms and 14 poles. The cheap Turnigy or Ezrun ESC's are better than more expensive sensoreless ESC's. Last edited by Toy Master; 03-01-2012 at 03:53 AM. | |
03-01-2012, 04:06 PM | #34 |
Pebble Pounder Join Date: Oct 2011 Location: Meridian
| Re: how long are your motors? You gonna use the internal washer method, to increase the strength of the shaved housing?
03-01-2012, 04:40 PM | #35 |
I think I burned up an esc so I'm going to try the brushless route if I did.
03-01-2012, 05:59 PM | #36 |
| Re: how long are your motors? I'm still thinking of butchering my stock housings, trying to move the entire mounting plate over a bit farther. I don't want to cut until I have a good plan. It would be a shame to take the ZNO plate off my big-boys, when I could sell em cheap to you guys. |
03-01-2012, 06:12 PM | #37 |
for realz!! |
03-01-2012, 11:52 PM | #38 | |
Pebble Pounder Join Date: Jan 2012 Location: middle earth
03-02-2012, 03:16 AM | #39 |
I got the FIRST experimental 540 gearcase cut and done!! I moved the mounting plate over 5mm. My HH torque masters will sit 3mm tighter than the stock 390's did!!!!!!!! Thats 12mm, or 1/2inch saved from my current setup. And I think they will be plenty strong. I'll get pictures up tomorrow, probably after I get a motor mounted on them. |
03-02-2012, 10:14 AM | #40 |
That's what I thought. I went with motors 36mm long. I also for fun bought some 3850kv's. I know the torque will be crap but for the few seconds to swap them in I thought it would be fun to have motors that are 4x faster then the ones I selected. |
BRAINSTORM; Moving Those Motors - Similar Threads | ||||
More power and faster moving forward than moving backwards? | StickyWheels | Losi Micro-Rock Crawler | 8 | 01-07-2012 09:11 PM |
1.9 tow rig brainstorm session. | JohnRobHolmes | 1.9 Scale Rigs | 26 | 11-26-2008 09:31 AM |
brainstorm for simple 2 channel radio dig setup | TJeeperMan | Electronics | 10 | 10-20-2005 08:59 PM |
