03-05-2012, 12:16 AM | #41 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Re: BRAINSTORM; Moving Those Motors
Haven't mounted the motors yet, and haven't been around to work further on the mod yet. TONNES more to finish, But when I do, This mod is gonna be awesome!!! I'll put it all in it's own thread, but here's a teaser pic. Thats 5mm more clearance than stock housing! |
03-05-2012, 03:45 AM | #42 |
Pebble Pounder Join Date: Sep 2010 Location: Brussels/Belgium
About those brushless motors, what power supply are we talking about? Would the stock ESC resist them?(or a CC SCT esc, that's what I actually have) |
03-10-2012, 03:19 PM | #43 |
So no one can juste clear that out for me?
03-10-2012, 06:06 PM | #44 |
Rock Stacker Join Date: Aug 2011 Location: canada
might want to start a new thread. maybe more will see it ?? just a guess tho, i think the brushless motors need brushless esc's because they are ac not dc ?? dont take my word for it tho. Last edited by screwed; 03-10-2012 at 06:08 PM. |
03-10-2012, 06:21 PM | #45 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
They are using some cheap, double brushless esc. |
03-12-2012, 01:12 PM | #46 |
Newbie Join Date: Feb 2012 Location: Readyville
If you really want to get the motor out of the way, you could just flip the bottom half of the axle and make it hang over outside Plus it would make for better weight distribution if you do it in the front AND automatically give you BTA steering! What's not to like? Other than ramming your motor into things... Hmmm.
04-04-2012, 05:21 PM | #47 |
Pebble Pounder Join Date: Nov 2011 Location: Fresno
So has anyone that was kicking this idea of brushless around done it? There is a new option finally available from Holmes Hobbies. I have been watching this thread and another from the Electronics forum.. Sensored Outrunner motors- Revolver S He posted a testing vid today: Revolver S Crawler Motor.wmv - YouTube Specs: Holmes Hobbies / Holmes Bikes :: Motors :: Brushless Outrunners :: Holmes Revolver S Stubby Specs are incredibly in line with what we all are looking for (34mm can length) but since it ONLY fits 540s: ZNO Big Boys.. $ MANDITORY ALL metal parts in the axles... $ MANDITORY 2 motors... $$$$ MANDITORY 2 ESCs... $$$$ MANDITORY Batteries (ya gatta have better batteries, don't ya)...$$ (that's 10 $'s btw, not counting batteries) The option pointed out earlier in this thread is way cheaper, but..... |
04-04-2012, 07:20 PM | #48 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
what bout it? did you get motores mounted and worked so great you just don't want to share with us, or is it all still sittin where you took the last pic? just curious!
04-04-2012, 07:55 PM | #49 |
Me? No I haven't done it. Mine is still running the stock motors, til tomorrow when I get home that is . I will still be watching this thread intently, but the outcome won't be as needed for me anymore...
04-04-2012, 08:18 PM | #50 |
| Re: BRAINSTORM; Moving Those Motors |
04-04-2012, 09:30 PM | #51 |
Nope. I haven't installed the new gear case and motors yet. Not to mention that I've only built ONE gearcase, and haven't started the second one yet. I'm still rockin the rc4wd 45's for the time being. Sorry boys. Gettin lazy. And work started picking up again..........excuses, excuses.....blah, blah, blah....... I would like to make the second one a little prettier than my first hack job. I need a band saw, or a whole new machine shop for that matter. |
11-14-2013, 11:12 PM | #52 |
| code name; "STEALTH CASE" So here's the much anticipated update. code name; "STEALTH CASE" So What I'm doing here is moving the actual stock mounting plate, over 5mm. I'm cutting it out of one half of the housing, then removing material and mounting it into the other half of the housing. I'm keeping 3 screw holes attatched to the mounting plate to provide the strength. The glue is really just a filler, and isn't really factored into structural integrity. Though I'm sure it helps a bit. Last edited by The Jackalope; 11-14-2013 at 11:23 PM. |
11-14-2013, 11:37 PM | #53 |
These pics are from the first case I did. The second one came out a little neater. |
11-15-2013, 07:35 AM | #54 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
why not back it with styrene and fill it with epoxy? i think you will see some flex there, how much will depend on the motors. The big boy kit could be used to reenforce that section too. Edit*** another idea, once you have them right, re cast them and make molds......new gear case for the RS10! |
11-15-2013, 08:11 PM | #55 | |
| Re: BRAINSTORM; Moving Those Motors Quote:
I don't think flex will be an issue, cuz the load will be linear from the motor, no side loading. should be fine. If the pinion slips, I'll know this mod is busted. But I doubt it. I HAVE the Big Boy Kit. I'm trying to get away from the extra width it adds to the motor length. As it sits now, 9mm saved from the Big Boy Kit. | |
11-15-2013, 08:19 PM | #56 |
11-15-2013, 08:36 PM | #57 |
| Re: BRAINSTORM; Moving Those Motors So here's the issue. As you see above, The 10 tooth pinion doesn't reach the first spur gear, because the spur's shaft is in the way of the motor. The Big Boy Kit incorporates a hole to hold this shaft pin into it. But with this mod, the shaft IS where the motor housing SHOULD be. I was hoping to solve this with a 15 Tooth pinion to make up the extra distance. I'll be sacrificing some torque but gaining speed. I put a feeler thread on this topic, but got zero intelegent responses on the subject. (Sorry Doc) http://www.rccrawler.com/forum/redca...5t-motors.html The other option is to shave out half of the spur gears bearing shaft until the motor fits. this may affect how straight the spur gear sits in the case. However, the motor would also aid in holding it in place, since they will be touching. |
11-16-2013, 05:03 AM | #58 |
Well the question now is, how you do look on your mounting holes. Are you against the rear edge of the holes? You can open them up some I am sure you just want to have a little movement in there so you can get your lash right. This answers my previous question on space, yes you have room to go bigger. A 15tooth on a 35t motors should be fine. I was talking about filling the space you are currently filling with glue. Use styrene or some other thin material as a support and then fill the gaps with a good epoxy. Sent from my SCH-I545 using Tapatalk Last edited by Docwolf; 11-16-2013 at 05:06 AM. |
11-16-2013, 10:15 AM | #59 |
I haven't drilled the new mounting holes yet at 540 hole spacing. I was waiting to see where everything sits when my new pinions arrive. Then I'll drill out as little as possible to tune gear mesh, and throw a washer on the screw-head side. As The pic with the motor in it shows; I'm running my pinions upside down on the motor shaft to line up properly with the spur, since the motor face is that much closer to it. Also, with the case assembled, the small cover-plate over the pinion won't fit as is. I'll either Fabricate a "domed" cover plate to clear the pinion, or just run with it open. the glue is E600. I use it to repair my lexan bodies. |
11-16-2013, 10:27 AM | #60 |
And thanks for your input Docwolf. I'm still worried about drawing a lot of amps on the 35t's with 15t pinions. Guess I'll have to wait and see though. I'd rather follow with the HH moto of "Volt up and Gear down" cuz it sure makes a lot of sense. But, only driving it will tell. I can't wait to start testing |
BRAINSTORM; Moving Those Motors - Similar Threads | ||||
More power and faster moving forward than moving backwards? | StickyWheels | Losi Micro-Rock Crawler | 8 | 01-07-2012 09:11 PM |
1.9 tow rig brainstorm session. | JohnRobHolmes | 1.9 Scale Rigs | 26 | 11-26-2008 09:31 AM |
brainstorm for simple 2 channel radio dig setup | TJeeperMan | Electronics | 10 | 10-20-2005 08:59 PM |
