Fitting GMade R1 chassis Im planning in getting a gmade r1 chassis because they look bad ass. My question is do all the stock links fit or soon need to get some different links? Also are the factory shocks ok or should I invest in some better ones for the chassis? Thanks guys!! Lee |
Re: Fitting GMade R1 chassis Stock length gmade upper and lower gmade links...will need to be bent. Stock shocks are good |
Re: Fitting GMade R1 chassis So I can't use either rs10 links? And the gmade ones need to be bent? How do I bend them? How much angle? |
Re: Fitting GMade R1 chassis I just read your thread on your chassis build. No chance I can do all that, so maybe I'll go a different route. |
Re: Fitting GMade R1 chassis I am in the process of doing this right now. The links physically bolt up(with some hardware changes), but the angles are a little wonky, and the top links are too short, which throws the top of the axles in too far. The shock mounts made my stock shocks stand straight up, and lost all my flex... so I started modifying! I fabbed up some aluminum side cover plates, which gives me a solid place to mount my shocks at an angle closer to stock, which is bringing my flex back. http://farm8.staticflickr.com/7215/7...e7f4a2b896.jpg As far as the top links, I was going to make new ones, but I think I will move the top axle mount farther forward, and drill new holes in the axle housing. That will effectively lengthen my links, and I can drill the hole in the mount for the links lower, which will get them more parallel with the bottom links, which hopefully will make the wonky go away. So far I love the chassis though...looks cool, and about 8 out of 10 rollovers leave me back on my wheels! Plus I'm not continuously destroying those rare, expensive Geo Tracker bodies I love so much!"thumbsup" I will be updating my "Godzuki .5" build thread with all of the changes I made to get this chassis to work(with pictures) when I get them done...so stay tuned. |
Re: Fitting GMade R1 chassis Quote:
You can transfer everything over, it looks a little weird IMO. There is a thread in here somewhere that a guy transferred all of his redcat gear over to a gmade chassis. Buy a couple of links at a time, before you know it you have all of them. |
Re: Fitting GMade R1 chassis I really kinda' regret not ordering the Gmade links when I ordered the chassis. Would have made life easier. I always seem to spend a dollar to save a dime though! |
Re: Fitting GMade R1 chassis Making the links is super easy...a drill and something to cut the aluminum is pretty much all u need...$4.00 for the aluminum rod 3' long. |
Re: Fitting GMade R1 chassis Anything new on this suspension set up your trying to accomplish? I've got the same set up with aluminum skins I just made. Would love to get more flex. I've got the lower links moved inward and bent for high clearance. I've also got the upper links mounted in triangulation on the top center of each axle. |
Re: Fitting GMade R1 chassis I'm thinking of doing the same thing with my rs10. Could u buy 130mm shocks and mount them Uptop. Stock rs10 shocks are 100mm so 30mm more should give some angle? Am I right? Sent from my iPhone using Tapatalk |
