07-16-2012, 01:49 AM | #1 |
Newbie Join Date: Jul 2012 Location: southcentral
| axle housing breakage
has anyone ever broke the housing in half i will add pics when i figure out how Last edited by mach10driver; 07-16-2012 at 02:31 AM. |
07-16-2012, 02:33 AM | #2 |
| Re: axle housing breakage
sorry in my redt cat rs10 crawler
07-21-2012, 11:39 AM | #3 |
Newbie Join Date: Apr 2011 Location: San Diego
How in the world did you manage to break the axle housing?!?! You will need to buy a new one. It needs to be strong so I wouldnt bother trying to fix it. I think you can order directly from the redcat website. You can also try asking around. Maybe someone has one they can send to you. Good luck!
07-21-2012, 12:02 PM | #4 |
Newbie Join Date: Dec 2011 Location: Temecula
Have seen 2 broken housings lately, get a new housing and install beef tubes in it
07-21-2012, 12:07 PM | #5 |
i ran it for a little bit one day and then i picked it up and i dropped it from a foot off the ground and it broke i fixed it by platic welding it for awhile and broke again so i got a new housing from rufaster.com it was fast shipping i order it on sunday and got it tuesday i get pics of the housing broken
07-21-2012, 12:28 PM | #6 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
you must be short or have long arms if it only fell a foot.
07-21-2012, 01:12 PM | #7 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| Re: axle housing breakage |
07-22-2012, 11:40 AM | #8 |
Quarry Creeper Join Date: Jun 2010 Location: casper
pm sent
07-22-2012, 11:42 AM | #9 |
Rock Stacker Join Date: Feb 2012 Location: Everett
07-24-2012, 12:29 AM | #10 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
A beef tube could be made, but because of the dogbone cup inside the housing, the tube would need to fill in the taper inside the housing, as well as having reliefs for the screw bosses protruding inside the tapered section to work properly. It won't be easy, but it could be done.
07-24-2012, 12:41 AM | #11 |
| Re: axle housing breakage Last edited by mach10driver; 07-24-2012 at 12:43 AM. |
07-24-2012, 12:46 AM | #12 |
07-24-2012, 12:49 AM | #13 |
i cut the front tires one way and i cut the rear tiresanother way |
07-24-2012, 07:09 AM | #14 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
I am going to say that there was a crack there already.
07-24-2012, 07:59 AM | #15 |
After seeing the pics in post #11, I don't think a beef tube will help, your going to need a complete bottom half of that axle housing in aluminium.
07-24-2012, 08:52 AM | #16 |
This is a isolated event, you know how many times I have dropped mine of a cliff or rolled it down a hill? neither do I, but it numbers in the several range. so i am saying beef tubes are not needed. something was wrong with eh tube from the start or we are not getting the whole story. the rig does not weight enough to do that damage from any height of a drop, excess force was required to break that housing.
07-24-2012, 03:14 PM | #17 |
there had to be a hair luine crack that i couldnt see cause ive seen them fal from higher and flip alot
07-24-2012, 03:16 PM | #18 |
today i put lower bent links and use the stock lowers for the new uppers
axle housing breakage - Similar Threads | ||||
ax10 axle breakage or no breakage | Oregon crawler | Axial AX-10 Scorpion | 12 | 08-15-2011 03:20 PM |
axle breakage | davidyack | Newbie General | 2 | 01-18-2011 05:36 PM |
pti axle shaft breakage | fanto57 | General Crawlers | 3 | 12-27-2009 09:13 PM |
Axle breakage - update? | SeanD | HPI Wheely King | 12 | 10-09-2007 06:34 PM |
e maxx axle breakage | rbl | Newbie General | 6 | 01-14-2006 05:45 PM |
