03-23-2013, 05:17 AM | #1 |
Rock Stacker Join Date: Mar 2013 Location: Newfoundland
| Problem with rear axle
Hey guys, got a rockslide and love it. Only thing is I've noticed that the back wheels are harder to turn(Not steering...fwd and rev) than the front. I have to use a lot more force to get them to move almost like something is too tight. There is no binding on the rims to knuckles etc its somewhere in the diff. HAs anyone else had a similar experience? If so what was your fix? Thanks Newfie |
03-23-2013, 07:58 AM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Problem with rear axle
take it apart and see if something is broken or binding. learning to work on your 10 is half the fun.
03-23-2013, 08:19 PM | #3 |
Quarry Creeper Join Date: Feb 2013 Location: prather
Check to see if the set screw for the dog bone cups has backed out. Or the spur gear screws.
03-24-2013, 03:58 AM | #4 |
I actually found out it was the rear motor. These things can't take much punishment!! Only used it in to house cause its winter still here. I'm really impressed with it, maybe more when i get some mods done and perhaps some new motors. BTW My fix for the pins coming lose on the dog bones.....Roll Pins! Knock the old pin out and tap the roll pin in, use dremel and cut to size. small screwdriver and expand the ends a little. They will never come out again unless u want them too!! GL all thanks for the replys!
03-24-2013, 10:03 AM | #5 |
I just had a rear motor problem to Lol I think I Got a small rock in it. But other than poping wires off With the tires no problems with the motors.
03-25-2013, 08:23 AM | #6 |
Rock Stacker Join Date: Mar 2012 Location: Colorado Springs
Yep my motors have run strong for the past year, and still are. But I drive carefully (as in always stopping before going from forward to reverse, ect...)
03-25-2013, 01:33 PM | #7 |
I think my son may have done the damage to it...oh 4yr Olds
04-01-2013, 12:52 AM | #8 |
| Re: Problem with rear axle |
04-17-2013, 11:02 PM | #9 | |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Problem with rear axle Quote:
Would it hurt anything to cover the motor holes with aluminum tape to keep rocks/sand/water out? Also I was thinking of using marine grease to plug up the smaller holes on the end bell but I don't know whether it is electrically conductive and would require keeping the + and - grease separate. | |
Problem with rear axle - Similar Threads | ||||
Rear axle problem | tinycrites | Axial Wraith | 7 | 03-04-2012 08:45 AM |
Rear axle "clicking" problem/solution. | GRIMGREG | Axial AX-10 Scorpion | 1 | 07-04-2011 02:27 PM |
Super Rear Axle Problem | Real Hustler | Superclass Crawlers | 4 | 10-11-2010 10:26 PM |
cc-01 rear axle problem | akhoundog | 1.9 Scale Rigs | 7 | 04-30-2007 01:15 PM |
Rear Axle Problem | txrenegade | General Crawlers | 1 | 02-09-2006 04:06 PM |
