rs10xt cg lower so what I did was took the shocks and put them on the post screw. simply by taking the post screw out and using the shock screw to tighten the body in. and surprisingly it went perfect. I did not have to change anything or mod anything to fit it all I needed was a screw driver and a pair of pliers. next i unscrewed the lower screw to the shock so it would loosen. I slid it down to about an 1/8 of an inch to the plastic connector. and I tightened the screw. I did this on all 4 sides and now it has alot lower cg. |
