Rs10 xt rock racer What can I do to make my rs10 xt a rock racer? I have already upgraded to steel gears do I just need faster turn motors? Also I have the hobbywing dual brushed speed control |
Re: Rs10 xt rock racer Quote:
Hate to be the bearer of bad news, but the RS10 isn't that great of a platform for a rock racer. The steel gears are a good start for durability, but I'm pretty sure the dog bones won't hold up to rock racer speed and abuse, not to mention you won't be able to beef up the axles like a lot of guys do for the Axial based go-fast rigs. Best of luck to you on the project, though. |
Re: Rs10 xt rock racer I got more speed running 3s on the stock motors but not enough to call it a "rock racer" by any stretch. Without getting creative and cutting up the axle and installing metal tubes and grafting on metal Chubs the part I broke the most were the molded in chubs. I never snapped a stock axle or tore out a stock cup but I spun out that stupid plastic spur plate a bunch of times and finally came up with a method of beefing that using a piece of allen key for the pin and JB weld in the plastic slot. That will make it more durable than stock but not enough to handle big power. Considering that I have snapped some extremely beefed Axial shafty housings and tore up a bunch of beefed XR10 housings I would not heap scorn on the RedCat...you need all metal parts to take big power and even then I see guys tearing up VP curries in their racers. Itsy bitsy parts just are not engineered for massive loads. |
Re: Rs10 xt rock racer It would probably be easier to do with the shafty redcat. Then you could put a much larger choice of motors and you'd have all the axial parts to work with. |
Re: Rs10 xt rock racer a friend of mine built his 10 for speed , after about 10 min. parts were flying and breaking. you can only do so much with the 10 without putting a ton of cash into it. when I started modding mine I could of bought 2 better rigs with the cash i put into it. |
