07-19-2018, 12:33 AM | #21 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: axial parts in my everest axles
I had a set back with my c-hub and knuckle order. But refunded. Ill buy another set somewhere else Friday.
07-23-2018, 08:53 AM | #22 |
I have new c-hubs and knuckles coming. Once they are here ill build the front axle.
07-29-2018, 02:38 PM | #23 |
Standard front axle with servo post trimmed Axial parts going in these are all OG scx10. Spool, HD standard gears, GDS RACING c-hubs and knuckles(these are 8 degree set up) and cheap eBay CVDs. Plus the lockeduprc bearings I had leftover from my rear axle build. Axle tore ready for parts and modification. Side by side of gears and lockers Stock is just plastic. Spool is sold steel and adds a little weight down low. |
07-29-2018, 04:12 PM | #24 |
I started by clean up the bottom to be more rock friendly Here is my rear axle smoothed out showing about how far you can go. Here is where the mods start as you can see below the nubs are tall. The first mods is to shave these down till the c-hubs slides down to its resting place. Go a little bit at a time till it fits and is tight. Now after it slides past the nubs Comes more mods. As you can see resting place you still can't bolt up. With these c-hubs I had removed 2mm from the c-hubs. Your mileage may vary. Also the outer bearing retainer needed removed to flush with the bearing. You can see everything fitted. (More on this step in a bit) |
07-29-2018, 04:27 PM | #25 |
| Re: axial parts in my everest axles |
07-30-2018, 12:30 AM | #26 |
Next mod since I shaved down the housing and c-hubs. There is some binding in the CVDs. Again just a few mm. But enough so things don't play well. This is stock cvd What I did was grind down the flats to engage the spool more. Here I took away the flange. If I run in to a bearing retention issues I could sandwich a washer or something to help with that. |
07-30-2018, 12:49 AM | #27 |
axial parts in my everest axles - Similar Threads | ||||
Redcat everest 10 upgrade parts | Joshcail | Newbie General | 7 | 12-31-2016 07:42 PM |
how to make strong RS10 axles? or everest 10? | dirtman71 | Redcat Crawlers | 12 | 07-22-2015 09:01 PM |
Everest 10 axles worth upgrading? | bryner250 | General Crawlers | 0 | 06-27-2015 06:54 AM |
