Easy conversion to rear lockouts for Everest 10 FYI, you can easily convert your Everest 10 to rear lockouts using parts from the Gen 7. You will need part numbers 13815 and 13816. It takes most of the slop out of the rear axle and also nets quite a few spare parts for your front axle. |
Re: Easy conversion to rear lockouts for Everest 10 That's probably worthwhile just for the sake of getting the rear tierod (anchor) out of the way. ..or you could go the other way and buy another servo mount, servo, and Y harness for cheap and easy 4ws. |
Re: Easy conversion to rear lockouts for Everest 10 Great info! Will make the rear axle on my Scalers look great! https://uploads.tapatalk-cdn.com/201...6bc2ec796e.jpg Sent from my SAMSUNG-SM-G900A using Tapatalk |
Re: Easy conversion to rear lockouts for Everest 10 Note that the Gen7 rear axles mentioned in first post have 5mm shaft OD, so the stock wheel hexes of the E10 won’t fit. I ordered 2 sets of both part #’s and put the parts on one of our E10 axles this evening and found the hexes don’t fit. The shafts and lockouts fit great, just gotta get some hexes that will work. |
Re: Easy conversion to rear lockouts for Everest 10 Quote:
Re: Easy conversion to rear lockouts for Everest 10 Any reason you couldn't just bore out the stock E10 hexes to the right size? If not, you could just get the stock Gen 7 hexes. |
I ordered the 7mm wide hexes linked below. I *think* they should work out just right. Aluminum Hex Hub 7mm12mm Black (4) |
Re: Easy conversion to rear lockouts for Everest 10 So we got the above linked 7mm hexes in the other day. I had to drill the 4-5mm step down in them out, as they wouldn't slide on the axle far enough to reach the cross pins. :???: I measured the axle shaft OD with calipers and found the # drill bit that matched it closest (not a regular drill bit set, but a set of "Numbered Drill Bits"), so the hexes are a snug fit on the axle OD. Also had to use a smudge longer screws in the hexes, which I had on hand anyway, so no big deal. The result is, the axles / lockouts / hexes now fit & work perfect :ror: |
