01-30-2018, 11:11 AM | #81 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Gen7 Aluminum Knuckles Available!!!
The no name axle assemblies that are all over Ebay. https://www.ebay.com/itm/US-2pcs-Axl...IAAOSwNkJaDs6F |
01-30-2018, 06:31 PM | #82 | |
Rock Stacker Join Date: Nov 2017 Location: Trumansburg, NY
| Re: Gen7 Aluminum Knuckles Available!!! Quote:
01-31-2018, 06:25 AM | #83 |
There are a number of guys in the Gen7 Facebook group running them, but it's been a week or 2 since they posted their installations, so they're buried and I can no longer find them. I recall one guy breaking a CV axle on his first drive, but that may have been a fluke because I only saw that from the one guy. Don't feel foolish for taking the path you did. The systematic approach is always more educational than the "all at once" approach. You have a much better understanding of what the individual limitations of the parts are, and that's always good to have. I've never been a fan of the "replace the whole thing" approach, even though sometimes it's the right answer. I almost always piss more money into the "piece at a time" approach just so that I can have the more in-depth understanding of the inner workings (and limitations), THEN I replace the whole thing. |
01-31-2018, 09:41 AM | #84 |
Newbie Join Date: Feb 2017 Location: West chicago
Didn't know there was a facebook group! I just asked to join. There's one guy I know that got that aluminum axle set from eBay. He loves it! I'm guessing it's a bit heavier, too which would be cool! But not sure I like the look of it just yet. I like black axles, myself. |
02-02-2018, 05:58 PM | #85 |
Newbie Join Date: Jan 2018 Location: US
After lots of searching and videos and talking myself out of doing this several times, I decided to go with the vader skid plate and upgraded the driveshafts with the pro version so everything will drop in place without modification. I couldn't justify spending twice as much of driveshafts that would require modification or replacing other parts to make things work. I may not get the steering angle I'm hoping for, but I think my goal is unrealistic without spending a lot more money than I'm willing, but it should be better than it is with the stock dog bones. Those cnc axles listed above do look pretty sweet and I even looked at some portal axles, but I'm not willing to spend that kind of money since it's not a comp crawler. Sent from my SAMSUNG-SM-N920A using Tapatalk |
02-11-2018, 10:38 AM | #86 | |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
02-11-2018, 11:52 AM | #87 |
I honestly haven't looked too closely at the backside of the front axle... has anyone attempted mounting the knuckles backwards and running the tierod over the driveshaft/under the servo? It would seem that the Redcat high steer knuckles would make that an easy(er) option, and would get a whole lot closer to true ackerman steering, making the inside tire turn sharper than the outside. I think the bigger hurdle there might be draglink routing, unless you went to a chassis mounted servo? Just getting the wheels turning, but I might play with that idea more when my son won't miss his truck for a day.
02-11-2018, 07:11 PM | #88 |
Newbie Join Date: Jan 2018 Location: Foothill Ranch
Newbie here - just got the new kit, and for the life of me, I can't figure out how to get the larger of the two bearings out of the previous steering knuckle. The small one just pushed out fine from the other side. Any tips for this? Crap, threaded rod stuck in the steering arm too. Whoops, I'm in trouble now! Last edited by nocturne1; 02-11-2018 at 07:34 PM. |
02-11-2018, 07:48 PM | #89 | |
Sent from my Moto G (4) using Tapatalk | |
02-11-2018, 07:54 PM | #90 | |
Now for this damn rod.... | |
02-12-2018, 02:16 PM | #91 |
To get the threaded rod out, run 2 3mm nuts down it and tighten the nuts against each other as tight as you can get them, then turn the bottom nut to back the threaded rod out of the link.
02-12-2018, 06:19 PM | #92 | |
Gotta find a fix before the long weekend! | |
03-21-2018, 07:43 AM | #93 |
I mentioned I'd give an update once the cnc machined axle got here. I created a new thread for any who are interested: CNC machined ebay front axle Install/review |
Gen7 Aluminum Knuckles Available!!! - Similar Threads | ||||
Aluminum C's n Knuckles ?? | DORK VADER | Axial AX-10 Scorpion | 15 | 02-06-2009 01:21 PM |
