01-17-2018, 04:43 PM | #1 |
Newbie Join Date: Dec 2017 Location: Bloomington
| Help With Everest-10 Drivetrain/Chassis Mods...
Hello fellow crawlers, I'm having a spot of trouble with my Redcat. My 20t motor and 14t pinion (finally) arrived and I threw them in the truck, only to find that apparently the 20t is a little bigger, as the motor presses right ip against the side of the TVP chassis plate and leaves no room for adjusting pinion/spur mesh. It physically fits, but the gears grind like nothing I've heard before. Anybody have any ideas about how to relocate the gearbox or somehow clearance the motor in another way? I'm slightly worried about drilling holes in the plastic bottom chassis plate, as the holes may combine and ruin the plate over time if I don't relocate it far enough away. Any ideas are appreciated! Thanks [IMG][/IMG] [IMG][/IMG] |
01-17-2018, 04:50 PM | #2 |
Quarry Creeper Join Date: Aug 2017 Location: KY
| Re: Help With Everest-10 Drivetrain/Chassis Mods...
You could probably put some 3mm washers between the chassis plate and skid plate and battery tray. May need to stack a few of them and use longer screws if needed.
01-17-2018, 05:22 PM | #3 | |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Help With Everest-10 Drivetrain/Chassis Mods... Quote:
1 do as #9 suggested 2 redrill the skid. Its been done plenty of times to fit a scx10/ax10 trans. I'm going to redrill my sons skid for a different motor issue. 3 a new chassis either scale or comp style. | |
01-17-2018, 05:30 PM | #4 |
| Re: Help With Everest-10 Drivetrain/Chassis Mods... Thanks, any suggestions you know of as far as comp style chassis? I would just go ahead and order the TCS XTrail scale chassis, however if have to order a new body as well and frankly I love the massive flex that the TVP chassis gives me.
01-17-2018, 07:04 PM | #5 |
Look in the ax10 section they call them sportsmens for the sportsmen comp class. also look I. The vendor section sub section chassis I've been toying the idea of making a Everest 10 in to a comp crawler |
01-17-2018, 08:45 PM | #6 |
| Re: Help With Everest-10 Drivetrain/Chassis Mods... Man, that Fastback II chassis would be killer on an E-10, too bad they aren't for sale anymore....
01-19-2018, 09:07 PM | #7 | |
Newbie Join Date: Mar 2017 Location: Mountain Home
Sent from my HTC One using Tapatalk | |
01-22-2018, 10:56 AM | #8 |
I really like the looks of that cage, and the price, but how durable is it? I've heard lots of reports of bad welds on integy products including this cage. It sure looks cool!
01-23-2018, 09:49 AM | #9 |
Pebble Pounder Join Date: Aug 2017 Location: Mesa
| Re: Help With Everest-10 Drivetrain/Chassis Mods... I beat the hell out of mine & it's held up just fine. I wouldn't hesitate to recommend it. Just keep in mind there's not allot of space in there so you have to get creative with your electronics & battery. I was able to get everything tucked inside, but I had to switch to 2200mah 3s. That's about the largest battery that will fit.
01-25-2018, 01:26 AM | #10 | |
01-25-2018, 09:35 AM | #11 |
I cut a chassie out of a cutting board the thing is unstopable now im gona add it to my diy chassie thread here soon i got some more material so im gona make a few for the hell of it ill do a video and a write up when i do theres no motor chassie interferance the links are kinda tigut though
Help With Everest-10 Drivetrain/Chassis Mods... - Similar Threads | ||||
Top Everest 10 mods and upgrades | StomperCrawler | Redcat Crawlers | 23 | 01-25-2023 06:45 AM |
Everest 10 to TCS X-Trail chassis | TIME MACHINE | Redcat Crawlers | 6 | 09-11-2016 12:35 AM |
Tube chassis for everest 10 | thabeast2002 | Newbie General | 1 | 06-22-2016 11:53 AM |
