04-19-2018, 07:28 AM | #81 |
Rock Stacker Join Date: Feb 2018 Location: Central
| Hello
I also found out the clamping style wheel hexes I got are essentially garbage as well. They look nice, but the tiny screws strip before they provide any measurable clamping force so I went back to the stock redcat aluminum pieces with a mod to get their grub on. There is 0 wobble now between the hex and the stub axle. Sent from my iPad using Tapatalk |
04-19-2018, 07:35 AM | #82 | |
| Re: Hello Quote:
The stock plastic ones were fine actually, but I read of others stripping them so that upgrade was more preventative than necessary. They just wobbled on the axle and I didn’t like it. Sent from my iPad using Tapatalk | |
04-19-2018, 07:37 AM | #83 |
Newbie Join Date: Apr 2018 Location: US
| Re: Hello
I'm split between upgradeimg to axial axle assembly's or riping the stock loclers out and wheel hexs and going alum Sent from my LG-K371 using Tapatalk |
04-19-2018, 07:51 AM | #84 | |
| Re: Hello Quote:
I took the stock diffs apart and filled the voids with jb weld for now. Also greased the ring and pinion since they were dry. Beyond that, I’m considering full replacement of the entire assemblies with aluminum. Steel driveshafts, aluminum trans case and steel gears. That’s mostly why I’m still running nimh packs or 2s at the most. Sent from my iPad using Tapatalk | |
04-21-2018, 05:58 AM | #85 |
| Re: Hello
After replacing the broken lower link rod end I saw they were all rubbing on the skid from the angle of moving them inboard so RC4WD helped out with some new bent pieces. The draglink was also hitting the pumpkins at full lock after grinding off the knuckle stops so some offset ends took care of that as well. Sent from my iPad using Tapatalk |
04-21-2018, 10:08 AM | #86 |
| Re: Hello
The heap seems to be working fairly well. We’ll see if it’s better or worse after the mail runs today. Sent from my iPad using Tapatalk |
04-24-2018, 09:49 AM | #87 |
| Re: Hello Some parts for an upcoming project. For giggles I stretched a 1.9 tire onto the 2.2 wheel and it failed miserably. And then this roll bar showed up and made it better. Sent from my iPad using Tapatalk |
04-26-2018, 01:22 PM | #88 |
| Re: Hello
Yeah, that’s not gonna work. Thought I would be a little different from the Jeeps,Rovers,etc and took a chance on an hsp Hummer shell knowing only the overall length. As it turns out it would need about a 10.5 inch wheel base and probably 1.55 wheels and tires, not to mention all the suspension and driveline work to shorten everything, so it goes on the shelf for another day and another project. Sent from my iPad using Tapatalk |
05-02-2018, 02:26 PM | #89 |
| Re: Hello
Now it begins.... the upscale project. H3 shell just in case. Sent from my iPhone using Tapatalk |
05-02-2018, 06:20 PM | #90 |
| Re: Hello
Moved this to a new thread in large scale. This won’t be a rebodied redcat Everest 10. My gf just got the e10. She watched me unbox the hummer and said “that thing needs to be tricked out.” She has no idea what she just said,lol. Sent from my iPhone using Tapatalk |
05-05-2018, 01:19 PM | #91 |
| Re: Hello
Revo 3.3 body unloaded. Ready to roll with batteries. Sent from my iPhone using Tapatalk |
07-21-2018, 11:18 AM | #92 |
Quarry Creeper Join Date: Jan 2016 Location: Wichita
| Re: Hello
Looking mean. What's next? Sent from my SAMSUNG-SGH-I747 using Tapatalk |
07-25-2018, 09:03 AM | #93 |
Newbie Join Date: Jun 2018 Location: Buffalo
| Re: Hello
Hello Guys! Nice Trucks! E10rc, Where did you get the roll bar for the Everest? Is it from rc4wd? Also..... What wheels are those, Please and thank you, and keep up the nice work!! Thanks Adam |
