03-26-2018, 07:35 PM | #1 |
Rock Stacker Join Date: Feb 2018 Location: New Braunfels
| Already having trouble out of my sons Gen7. What could ut be?
Ok. We got 2 gen7 pro rigs 3 days ago. The first day my sons battery dies almost 1 hour before mine dies. His esc and battery were very warm. I chalked this up to his throttle control. LOL. Day 2 we had been on the trail about 30 minutes and his truck stops responding to the controller. We turn it off and back on, this fixes it and works fine. Then again his battery died way before mine. The battery and esc were hot again. Even though he did not run it near as hard as I did mine. Then today about 45 minutes into our trail run, his truck just starts going on its own. Had to turn down throttle trim to catch it. Turn truck off and back on works fine for about 30 minutes. Then battery dies way too soon. Esc was very warm this time and the battery was not. Put my battery in it and 5 minutes later it takes off on its own again. Last edited by Nobody79; 03-26-2018 at 07:46 PM. |
03-26-2018, 07:46 PM | #2 |
Quarry Creeper Join Date: Jan 2016 Location: Wichita
| Re: Already having trouble out of my sons Gen7. What could ut be?
The very FIRST thing you should do, is take the pinion off the motor and make sure the rig will free roll on a slight decline, both forward and backward. If not, you have binding somewhere in the drive train. I would try swapping the transmitter and receiver of the trucks. If the problem transfers to your truck, then you know it's the transmitter or receiver. So, then, you bind his receiver to your radio. If problem continues, then it's the receiver. If not, bind his tx to your rx. If problems, it's his tx. You could swap the receivers back over and then swap his ESC into your truck and visa versa (that's what I would do FIRST). If the problem transfers with the ESC, something could be bad. Learning to troubleshoot is one of the most important things in this hobby. Most of it (unless you have advanced electronics or computer skills/equipment) is trial and error. Sent from my SAMSUNG-SM-G900A using Tapatalk |
03-29-2018, 06:56 AM | #3 |
Newbie Join Date: Mar 2018 Location: Raywick
Could be the gear mess, if it is to tight if will cause more strain and load on everything. This will deplete the battery faster, and make the motor and esc hot.
03-29-2018, 09:30 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Already having trouble out of my sons Gen7. What could ut be? |
03-30-2018, 03:06 PM | #5 |
LOL but is the mesh is not right it may be a mess! LOL |
04-17-2018, 06:39 AM | #6 |
Did you get your rig fixed?
Already having trouble out of my sons Gen7. What could ut be? - Similar Threads | ||||
Some Gen7 updates | Mikelangelo | Redcat Crawlers | 9 | 10-03-2018 06:39 AM |
Gen7 Aluminum Knuckles Available!!! | Everest10Dad | Redcat Crawlers | 92 | 03-21-2018 07:43 AM |
Redcat gen7 with 2.2’s? | rj_dio | Redcat Crawlers | 9 | 01-14-2018 08:51 PM |
gen7 sport | crawlhog | Redcat Crawlers | 1 | 12-28-2017 12:45 PM |
