Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Gen7 Pro tire foam
Old 09-05-2018, 08:42 AM   #1
Default Gen7 Pro tire foam
Just purchased a new Gen7 Pro and the tire foams seem very soft. I also noticed that the foam in the spare on top is noticeably stiffer. Should the Pro truck have the stiffer foam that is in the spare or the softer foam that is in the other 4 tires?
Brew52 is offline   Reply With Quote
Old 09-05-2018, 08:31 PM   #2
Natedog's Avatar
Default Re: Gen7 Pro tire foam
Brew52, ime the four tires are probably softer because they’ve been run. Foams soften with use. Redcat Gen7 tires are same size as Vaterra Ascender Swampers and I like Proline single stage blue 1.9 foams with them. If you want softer use their dual stage.
Old 11-19-2018, 12:36 PM   #3
Brew52, I just unboxed a Gen7 Pro, and all five of mine feel the same. The amount of sidewall bulge is very close to my 1:1 Rubicon running about 5 PSI.
ParrotHead is offline   Reply With Quote
Old 11-19-2018, 05:48 PM   #4
The Gen 7 Pro foams are a type of memory foam. I have found with mine that if the get any moisture in them to go very soft, once they dry out they stiffen back up again.
I ended up replacing placing them.
cjhike is offline   Reply With Quote
Old 11-19-2018, 08:24 PM   #5
Integy dual stage foams are a nice upgrade for the stock tires. Made a notable difference in how well mine climbed.
Sent from my SAMSUNG-SM-G891A using Tapatalk
ADlBOO is offline   Reply With Quote
Gen7 Pro tire foam - Similar Threads
Just got my gen7 pro downeast crawlers Redcat Crawlers 0 08-23-2018 08:11 PM
Gen7 Pro Sale jwwolf3 Redcat Crawlers 0 06-17-2018 06:10 PM
Gen7 Pro CVDs for Everest 10? Everest10Dad Redcat Crawlers 31 01-08-2018 05:46 PM
Gen7 pro stopped working toddtrx4 Newbie General 5 12-31-2017 10:07 PM
Deuce's Wild XL Foam Pair; 3.8" ID; Yeti XL Foam / BFG Krawler Tire Nova's Ark Crawler Innovations 12 08-31-2015 08:20 AM
