09-30-2018, 10:19 PM | #1 |
Rock Crawler Join Date: May 2009 Location: branchville
| Gen7 pro shock pistons
Has anybody tried making the holes in the shock pistons bigger in order to make the stocks softer? They feel to dam firm for my liking
09-30-2018, 10:57 PM | #2 |
Rock Stacker Join Date: Mar 2016 Location: US
| Re: Gen7 pro shock pistons
Have you tried changing the oil in them first? Sent from my SAMSUNG-SM-G891A using Tapatalk |
10-01-2018, 06:01 AM | #3 |
| Re: Gen7 pro shock pistons |
10-01-2018, 07:13 AM | #4 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
The springs are very stiff on the Redcats. Just changing shock oil or valving isn't going to change the super stiff springs, and will likely make it worse because those stiff springs will wind up under-damped and your truck will bounce like a cheap toy. SCX10 springs or Traxxas springs, along with a million other options, should all fit. Another thing you could do is stick with the stock springs, but lay the shocks down a little bit. You can make a plate out of scrap plastic that mounts to the factory shock mounts and repositions the shock mounting holes farther forward. The Gen7 portal axle kit comes with this type of plate and it softens the suspension pretty effectively. |
10-01-2018, 10:52 AM | #5 |
Rock Stacker Join Date: Sep 2013 Location: Great White North
The springs off of the Traxxas TRX4 fit, the Axial ones are too narrow. I installed the OEM ones off of the TRX4 on mine (TRX 8040 Rear & TRX 8041 Front). When I installed the portal axles the pan hard bar stiffened up the front a bit, so I went with a softer spring and installed the TRX 8043 on the front. Also I am running 20wt oil. Pretty happy with this set up! Couple of videos running this setup. https://m.youtube.com/watch?v=1Y1qXLZ1VWQ https://m.youtube.com/watch?v=BwFWrvu7CzM&t=44s Last edited by cjhike; 10-01-2018 at 07:27 PM. |
10-01-2018, 12:13 PM | #6 |
Newbie Join Date: Sep 2018 Location: Farmington
I've had two 1 hr crawls on some soft rs10 springs off amazon for like 9 bucks. I also changed the the weight to a 20wt oil. I did have to adjust the collars all the way to the bottom to get enough spring action. It has torque twist when you go full speed and wont track straight at 100% throttle but I like the slow really rocky crawls so I get way more flex and tire contact with these springs. |
Gen7 pro shock pistons - Similar Threads | ||||
How long is a gen7 pro shock eye to eye extended? | holycaveman | Redcat Crawlers | 4 | 02-24-2018 09:06 PM |
Shock Pistons | desertdude | Axial Yeti | 7 | 03-18-2015 04:47 PM |
Shock pistons | mgauger | Losi Mini-Rock Crawler | 7 | 02-28-2012 10:22 AM |
Shock pistons | husky385 | General Crawlers | 7 | 06-12-2010 03:38 PM |
Axial shock pistons in big bore shock bodies | Kanine38 | Newbie General | 2 | 03-11-2010 06:47 AM |
