01-25-2019, 09:12 PM | #1 |
Newbie Join Date: Feb 2018 Location: Greensboro
| Important info for Gen8 owners
Thanks to Triple X RC Garage on YouTube I found out the portal gears on the gen8 are bone dry. They without a doubt need to be greased. If you go on his channel on YouTube he shows you how to do it, being rather easy you simply take your wheel off, take out the 6 screws around the portal and add grease.
01-27-2019, 05:56 PM | #2 |
Rock Stacker Join Date: Apr 2006 Location: Clovis
| Re: Important info for Gen8 owners
Thanks for the heads up, my rear portal gears were greased, however lightly. But the front gears were dry..
01-28-2019, 08:27 PM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
Mine had some grease in them but not to my liking so I put some Lucas Red & Sticky in them. It’s pretty easy job, like was mentioned take the wheel off remove the 6 screws add some grease then reverse the prodeedure.
07-24-2019, 11:35 PM | #4 |
Newbie Join Date: Mar 2019 Location: Cashmere
Lubing everything made mine noticeably quieter.
07-25-2019, 05:28 PM | #5 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
Yes but that doesn't prevent the portal gears from braking. Yes end points are set properly.
08-16-2019, 04:56 PM | #6 |
Rock Crawler Join Date: Mar 2011 Location: sebastopol
I believe the portal gears break easily inside the cheap,weak plastic that the gears are supported by. I bought all the aluminum upgrades....had to wait for the aluminum knuckles for month to come over on the boat from China....I had paid for these in advance....they were on back order. The day after I recieved them hot racing released their brass portal outers that work on the plastic knuckles which are an absolute joke for strength once you add the extra weight. I ended up epoxying the void in plastic knuckles which lasted for a few hard runs. Then a month or so later got racing released their brass knuckles to pair up with their brass outer... why the delay???? Pretty lame in my opinion. Any I had faith,and more money then I wanted too... to give up 9n these underdog portals. That being said, I have all the redcat aluminum upgrades on the rear portal minus the center section,and aluminum upgrades on the front with the brass hot racing knuckles with their outer brass cover. I have yet to break any gears or anything in the portals since. I'm running these on an original scx 10 chassis with scx trans and a 2200 kv Holmes hobbies brushless puller motor with a 56 spur and 12t pinion....great low end capability with decent wheel speed to bump up obstacles. All this rig needs now is a transmission with fro t overdrive.....stay tuned for picks....as it's been year's since I've posted. |
08-16-2019, 05:19 PM | #7 |
RCC Addict Join Date: Nov 2010 Location: England
My portal gears on my PACK Gen8 were greased, but only lightly. I haven't done much else to it, but intend to do a full strip down now I have time. A bit bad since I bought the PACK in May, but have been finishing off my Venture SBK.
03-28-2020, 02:04 PM | #8 |
Newbie Join Date: Mar 2019 Location: Dover
My portals were greased, but with a very thin grease. I wiped them clean and put in some marine grease. I don't plan on taking it through any water, but just in case. Does anyone know how to get the transmission to quiet down? After I greased the portals they were silent, but that transmission is driving me crazy!! I've heard buying the aftermarket gears helps reduce noise, but I haven't tried that yet.
03-31-2020, 09:36 AM | #9 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
| Re: Important info for Gen8 owners I heard the same thing. Metal gears and a good mesh with the pinion and spur will quiet it down. I have the stock spur with a HH crawlmaster 12t and it doesn't seem too loud. Not as quiet as my stock TRX4, but quieter than my scx10ii with a castle and metal gears.
11-02-2020, 08:53 AM | #10 |
Pebble Pounder Join Date: Jan 2019 Location: Roanoke
So is it the portal gears that need to be greased, or is it also the loud transmission? Sorry to be replying to an old thread. I searched how to quiet the loud Gen 8 transmission and it brought me here
11-02-2020, 09:48 AM | #11 |
Greasing might help a bit, but steel gears will always be noisy.
12-02-2020, 10:05 AM | #12 |
Newbie Join Date: Nov 2020 Location: Miami
Any suggestions on what grease to use for a newbie. I have so many question, my head is spinning. What I do for my boy. Labor of love. |
12-03-2020, 06:08 AM | #13 |
Pebble Pounder Join Date: Aug 2020 Location: Ohio
Marine grease is a common product used.
12-03-2020, 08:39 PM | #14 |
Thanks vinceherman! Any suggestion on how much and what brand to buy? I am VERY new to this.
12-09-2020, 09:41 AM | #15 | |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Important info for Gen8 owners Quote:
Tags |
gen8, portals |
Important info for Gen8 owners - Similar Threads | ||||
VERY IMPORTANT INFO for Mini MOAB | CRAWLER-DAD | Arizona | 7 | 05-04-2010 11:54 AM |
Gsrc: Club Info Important!!! | Mav-1981 | Missouri | 27 | 07-10-2008 06:46 PM |
***Important Info for Holiday Orders*** | JohnRobHolmes | Vendors Miscellaneous | 1 | 12-22-2007 08:23 PM |
*IMPORTANT Nationals info!!!* | jason | General Crawlers | 1 | 07-07-2006 05:09 PM |
*IMPORTANT Nationals info!!!* | jason | RC Rock Crawling Worlds | 0 | 07-07-2006 10:39 AM |
