02-21-2019, 08:59 PM | #1 |
Rock Stacker Join Date: Sep 2018 Location: Pierce
| Gen8 wheel nuts?
Does the Gen8 normally not come with nuts that hold the wheels on just the plastic hub cover that screws on? I received mine and all it has is the plastic covers no wheel nuts. I’m guessing not since mine came with 2 wheels that had already came loose in the box but figured I’d verify. Mine was kinda a mess tho when I got it 2 pieces of the Velcro had already fallen off and the ESC was no longer stuck to the spot that it should have been and was just floating around under the body. My boy was wanting to drive it so I let him have at it and the wheel fell off and the hub that the wheel sits on is long gone and the pin that holds it to the axel went with it. First impression of the gen8 is not so good. Drove maybe 10 min and now we are down and out until I can round up parts.
02-21-2019, 09:32 PM | #2 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Gen8 wheel nuts?
There should be a normal 4mm lock nut holding each wheel on. The plastic cover is just cosmetic
02-21-2019, 09:38 PM | #3 |
Rock Stacker Join Date: Jun 2013 Location: Riverview
Just contact customer service. I have found them very responsive. Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-21-2019, 09:48 PM | #4 |
Sweet I sent in a warranty claim. Thank you guys for the help I figured it didn’t seem right but it is redcat so I figured when I put the new wheels that I ordered on I would just add wheel nuts. Hopefully they will actually stand behind their product. Just looks like who ever put it together didn’t bother to put the 4mm wheel nuts on.
02-21-2019, 10:44 PM | #5 | |
Quarry Creeper Join Date: Apr 2018 Location: US
| Re: Gen8 wheel nuts? Quote:
Sent from my Pixel 2 using Tapatalk | |
02-22-2019, 09:27 PM | #6 |
I got a reply from them asking for the part numbers for the parts I need. Problem is a couple of the parts are not listed on their site and and I’m not sure which pin it is that goes threw the 12mm hex and they don’t have the hex or the 4mm nut listed either. Does anyone have or know where they have an exploded view with part numbers listed?
02-22-2019, 10:29 PM | #7 | |
02-24-2019, 09:09 PM | #8 |
That is just what I was looking for. Where did you get the brake down?
02-24-2019, 09:30 PM | #9 |
The manual on the website has the exploded parts view. Sent from my Pixel 2 using Tapatalk |
02-25-2019, 06:48 AM | #10 |
| Re: Gen8 wheel nuts? |
02-25-2019, 08:22 AM | #11 |
| Re: Gen8 wheel nuts? Thats the long way around and at best your gona end up with a standerd lock nut i would go down to your local hobby shop and get some traxxass locknuts way better they will have the pin too there kinda standerd it might cost $10 or so but you will have them right away and have a simple not realy needed upgrade the stock lock nuts have a tendency to back off on there own
02-27-2019, 04:26 AM | #12 | |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
Gen8 wheel nuts? - Similar Threads | ||||
Wheel nuts | Bbknucks | Axial Yeti XL | 12 | 06-20-2015 06:26 PM |
What Wheel Nuts are best? | cmbscx10 | Axial Yeti | 4 | 01-05-2015 10:01 PM |
Wheel Nuts | Jabbz | Micro Scale Rigs | 2 | 02-01-2013 08:05 PM |
Need help, looking for these wheel nuts | DanBoTech | Axial AX-10 Scorpion | 3 | 07-26-2010 07:56 PM |
wheel nuts | muddeprived | Newbie General | 1 | 06-20-2007 08:33 PM |
