Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Soze adds a RedCat to the fleet - Gen8 Scout II
Old 03-11-2019, 01:15 AM   #1
Default Soze adds a RedCat to the fleet - Gen8 Scout II
Alright, So I ordered this way back in December, finally got in February, and haven't posted about it until March! I didn't want to post about it before, because I just haven't done much to it. In fact I still haven't, but I might as well start the thread now that I've run it a few times and have videos of it.
Videos of my Gen8 Scout II
Build Details:
RedCat Gen8 Scout II (Blue) RTR - https://ebay.to/2VwOsVY
Parts:
ProTek RC Low profile servo horn - https://ebay.to/2IO8av3
SSD RC M3 Bent Rod Ends - https://ebay.to/2IVGDIm
Pro-Line Racing #10128-14 Hyrax 1.9 G8 Rock Terrain Truck Tires - https://ebay.to/2C3dEg1
Pro-Line 1.9 Dual Stage Foam - http://bit.ly/2PLZsPk
Aluminum 1.9inches RC Beadlock - https://ebay.to/2YcmtNS
Electronics:
DS Servo DS3218 20kg Servo - https://ebay.to/2rjtcpW
Hobbywing Quicrun WP1080 - https://ebay.to/2C4BJn7
FlySky FS-GR3E 3ch Receiver - https://ebay.to/2TdkVDr
FlySky GT3C Radio - https://ebay.to/2VkVopp
soze is online now   Reply With Quote
Old 03-11-2019, 01:29 AM   #2
Default Re: Soze adds a RedCat to the fleet - Gen8 Scout II
Here's the first thing that I wanted to adjust. The steering geometry is off out of the box, and it kind of bothered me.
Look how far out in front the servo end of the draglink is. I haven't gotten around this part yet, but sooner or later I hope it can be addressed
Here you can see that the draglink and panhard rod are not at the same angle. The panhard rod has a steeper angle than the draglink.
Part of the reason for a shallower draglink angle is due to the stock servo horn that comes with the truck
Since I didn't have anything suitable on hand, I wanted to see if there was something I could do while I waited for the parts I needed. I ended up figuring out how to get the correct angle just by moving the tie-rod below the knuckle mounting point rather than above. This allowed me to get the correct angle while using the stock servo horn.
Don't have pictures, but here's the video: https://youtu.be/q2BiP4YPJfs
While I was at it, I took the opportunity to swap receivers. I thought the RedCat receiver would work with my FlySky GT3C since it's FlySky based, but apparently not. They must've done something to the Redcat version to make it RedCat specific. See the similarities between the RedCat and the Fly Sky Receivers?
Also took a look at my portal gears to see if they were missing grease. Lots of the earlier batches were reporting dry portal gears. Luckily my February release was all greased and ready to go.
Old 03-11-2019, 01:44 AM   #3
The RedCat body mounting system is a good idea, but the execution with the velcro left a little to be desired.
Here are some issues that I had.
Dropping the body straight on never worked well. The front just wouldn't stick.
This is the type of misalignment you get when you drop it straight on from the top
The secret to getting it mounted on correctly was to mount the front first, and then drop the back on.
Another issue is the side trim on the body prevents the body from mounting all the way down. It hits up against the sliders preventing the body from going down a bit more snugly.
This is something I'll address by trimming the sides, but I'm reluctant to do it until I get my magnets in. I'll be swapping out to magnets. It's the way to go.
Old 03-11-2019, 01:49 AM   #4
Despite those issues that I posted about above, I had a chance to take it out for a run, and it did pretty well.
I hate the way the stock tires look, and the foams were garbage. So I stuck the Pro-Line Hyrax with Pro-Line Dual Stage Foams on ebay beadlocks that I was using for my MST CFX-W.
Old 03-11-2019, 01:57 AM   #5
Another annoying thing. The driveshafts are out of phase, and there's nothing I can do about it on the stock shafts.
The steering geometry and these driveshafts make me wonder if it's just unfamiliar territory, or lack of attention to detail.
I was looking into the RedCat upgraded driveshafts, but HumboldtEF mentioned that they were still out of phase. I'll probably to see what cheap generic driveshafts might work on this truck.
I tried the Axial WB8 Driveshafts, and the length is good. The only issue with those is the different screw size diameter for holding the driveshaft in place. The Axial ones are a bigger diameter.
Old 03-11-2019, 02:05 AM   #6
Take two on the steering mod.
I decided to move the draglink from connecting at the tie-rod to connecting at the top of the knuckle like some others here have done.
The ProTek RC low-profile servo horn finally came in and I was all ready to go until I got this...
I couldn't get the angle I wanted, because the rod-ends didn't allow for it.
So I used SSD RC M3 bent rod-ends. They're roughly the same length in order to keep the draglink the same length as the panhard rod.
Now I'm a happy camper for as far as I can go without a new bumper/servo mount design. Side to side suspension bump steer improved with this change.
Old 03-11-2019, 03:17 AM   #7
Sketchiness abounds...
durok's Avatar
Cool write-up!
However, the last post is a double of the one prior to it...
Otherwise, extremely well-documented and informative.
durok is online now   Reply With Quote
Old 03-11-2019, 05:05 AM   #8
As always. Just posted this thread on my Facebook face and tag a buddy who recently bought a blue car. I urge him must read through this thread.
Teng is offline   Reply With Quote
Old 03-11-2019, 05:43 AM   #9
Where's my hammer!
kincer's Avatar
Great write up about these, I'm not happy about the front suspension geometry either, I'll get around to doing something with it at some point for sure though.
kincer is online now   Reply With Quote
Old 03-11-2019, 06:51 AM   #10
I did away with the stock rock sliders all together, they seemed to get hung up more than the skid plate.
Sent from my SM-G920R6 using Tapatalk
roadrashracing is offline   Reply With Quote
Old 03-11-2019, 07:14 AM   #11
Roadrashracing, what sliders did you replace them with?
4Aces is offline   Reply With Quote
Old 03-11-2019, 07:31 AM   #12
Interesting on the redcat rx, i used a redcat rx on my monster beetle and my flysky gt3c with no issues...
allanon1965 is offline   Reply With Quote
Old 03-11-2019, 09:29 AM   #13
Originally Posted by durok View Post
Cool write-up!
Yeah, RCC was acting a little slow and funky last last night... not sure how that happened.
Very nice. I still plan to trim the sides of the body though. If I raised the sliders up (which I plan to do for the time being) I would have to anyway. I'm still keeping an eye out for any sliders that I might like, but so far I haven't really seen any.
Yeah, not sure. It should've been as easy as putting the bind plug in, and binding it. Couldn't get it to take though.
Old 03-11-2019, 10:41 AM   #14
I'll have to fire up my flysky radio and see if it'll bind, I hadn't even considered it.
DukeMinnix is online now   Reply With Quote
Old 03-11-2019, 01:08 PM   #15
Hey Soze I recently did a custom build with wild boar shafts paired with Gmade axles. I had the same issue with the shaft pin being too big. Luckily I had a pair of Gmade shafts lying around, so I took the screw pin and they fit the wild boar threads and pin fit on the pinion. Hope that helps.
SlagMan is offline   Reply With Quote
Old 03-11-2019, 03:45 PM   #16
I think they were ssd scx10.2.
Old 03-11-2019, 05:25 PM   #17
I have found rc4wd bumpers with the outside tabs fit.
Old 03-11-2019, 07:02 PM   #18
durok's Avatar
That bumper is an excellent choice.
You guys are really making these Gen-8s look G-R-R-R-E-A-T!
Now about the shape of those fenders... (j/k)
Old 03-12-2019, 10:51 AM   #19
Nice work. I watching how these builds go. Might be a while, but I do like these Gen 8's.
I can't 'like' posts atm. Anyone else got this happening?
M1tch is offline   Reply With Quote
Old 03-12-2019, 10:57 AM   #20
If you let me know when you're hitting El Modina we'll come join you.
One of my crawling buddies just got one of these, I sent your thread link.
Browneye is offline   Reply With Quote
Soze adds a RedCat to the fleet - Gen8 Scout II - Similar Threads
Redcat Racing Gen8 Scout II RTR Overview and Video RPP Hobby RPP Hobby 0 03-08-2019 03:09 PM
RedCat Gen8 Scout II Hill Climb soze Scale Videos! 0 02-27-2019 11:07 PM
Win a Redcat Gen8! Locked Up Redcat Crawlers 6 01-25-2019 06:17 PM
Blue Gen8 Scout II DukeMinnix Redcat Crawlers 8 01-15-2019 01:16 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
