05-25-2019, 09:19 PM | #1 |
Rock Stacker Join Date: Apr 2019 Location: Olympia
| Made a steel skid plate for the Gen8
Last night I made a skid plate for the Gen8. I did it pretty quickly just as a test to see if it made much difference with pushing on the rocks and protecting the servo arm. I think its made from 1/8" steel so it put some good weight on the front. The aluminum I had was too thin and flexy. Also the hole spacing was just roughed out, It was getting late and I rushed through drilling the holes. I may remake it without the holes since they did catch on rocks a few times. First photo is from straightening it out on my anvil. My other hobby is blacksmithing, although RC Crawling has obsessed me over the past 2 months. |
05-25-2019, 10:48 PM | #2 |
| Re: Made a steel skid plate for the Gen8
nice job man!
05-25-2019, 11:37 PM | #3 |
Newbie Join Date: Apr 2019 Location: Central Mass
That came out nice well done. I ended up buying the skid but yours looks nice and should get the job done just as well. Take it easy Jay |
05-26-2019, 01:35 AM | #4 |
Thanks guys! I also want to make a set of sliders with some 1/4" Stainless bar I get from work. if/when I do I'll share the results.
05-26-2019, 07:09 AM | #5 |
If you relocate the servo you don't need to protect the servo horn you can fix the geometry while your in there and eliminate the bump steer so instead of hindering your performance you can increase your performance and make your rig stronger at the same time
05-26-2019, 11:46 AM | #6 | |
| Re: Made a steel skid plate for the Gen8 Quote:
I watched a bunch of YT videos last night actually about steering mods and even saw someone on my IG feed with a different servo mount. I also studied your posts about the mods you have done. How is relocating the servo done? I see a few 3d printed parts available.. but its hard to know what works and what doesn't. | |
05-26-2019, 06:03 PM | #7 |
you need to shave the front crossmember down about 1/16" then flip the servo horn and put tbe servo up front i ended up only using 2 screws to hold the servo in and there dosent seem to be any issues its a easy mod
05-28-2019, 10:14 AM | #8 |
| Re: Made a steel skid plate for the Gen8 |
05-28-2019, 02:00 PM | #9 |
| Re: Made a steel skid plate for the Gen8 i just copyed what the other guys were doing i think theres a you tube video about it i dont rember who it was done by but the only thing i did diferently was just use 2 screws in the servo i dident make any kind of mount for the second screw holes i figured its wedged in there pretty good so i dident worry about it
Made a steel skid plate for the Gen8 - Similar Threads | ||||
LG FAB Axial Wraith Stainless steel Skid Plate!!! | LGFAB | Chassis and Suspension | 8 | 08-05-2016 12:14 PM |
Steel skid plate? | Drm31078 | Axial RR10 Bomber | 7 | 04-05-2016 12:44 PM |
Steel or aluminium axil skid plate | Skier | Venom Creeper | 9 | 06-07-2011 01:07 PM |
