08-04-2019, 08:55 PM | #21 | |
Quarry Creeper Join Date: Jan 2016 Location: Wichita
| Re: Everest 10 broken steering knuckle, what fits as replacement? Quote:
You can do all the steering knuckle, c-hub, and link mods/upgrades you want and dogbone/drive cup axles will never perform as well as quality CVDs or Universals. Heck, I have Xtra Speed CVDs that outperform Axial, Losi, and Redcat/HSP doggone setups all day long. Minimum 10° steering improvement immediately. And, those are cheap! The one thing I do agree with is that they twist off easier if you're in to overpowering rigs, but I run 35T brushed on 3s lipo and never have a problem with them. Anywho, my apologies to the O.P. for veering down this rabbit trail. Sent from my SM-G955U using Tapatalk | |
08-04-2019, 10:38 PM | #22 | |
the dog bones have a bit more meat to them so they last longer and depending on the design can have better steering i have a redcat that has cvds on one side and dog bones on the other nether bind at full lock but i used to have both cvds but one let go so back to the dog bone | |
09-03-2019, 12:27 PM | #23 | |
Newbie Join Date: Aug 2019 Location: South Jordan
I want to do the XR mod but not 100% if it will work with the E10 axle housing as most of the mods are using SCX10 axles. | |
09-03-2019, 02:48 PM | #24 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Narrow beef tube you have to cut the c-hub mounting off the axle housing and drill and tap to mount the beef tubes in to the housing. As long as you can do that then yes it will work. It as been done before. Here are two post outlining the xr mod on E10 axles. Beef Tubes in Everest? SCX10 steering for E10 |
09-04-2019, 12:07 PM | #25 |
thank you. crazy in all my searches I missed both of those. Time to order parts! |
09-05-2019, 09:22 AM | #26 |
No problem. I do lots of research in to what I build and I had these bookmarked for easy finding.
09-06-2019, 07:34 AM | #27 |
for the narrow xrmod you dont need beef tubes thats just a added exspence just file groves in to.the nubs the original chubs mount to then slide the wraitb chub on and drill 2 new.holes for the screws to go in to very easy mod with huge results
09-08-2019, 12:07 AM | #28 | |
09-08-2019, 07:51 AM | #29 |
| Re: Everest 10 broken steering knuckle, what fits as replacement? |
09-17-2019, 09:56 AM | #30 |
Newbie Join Date: Sep 2019 Location: Rock Hill
| Re: Everest 10 broken steering knuckle, what fits as replacement? By using the file to lengthen the hole, did you have any issues with the length of the axle? I read through hillbillyrc's post about fitting the SCX10 hubs on an Everest axle, and he shaved the bottom of the hub. I'm more comfortable filing out a hole than shaving the end of a hub, so if your way worked out just fine, then I'd rather do that. Thanks.
09-17-2019, 10:06 AM | #31 |
Only reason I shaved the end was I want a tight fit and didn't have a file that fit the hole. But to each their own.
09-17-2019, 08:45 PM | #32 | |
i cant seem to get good pics sorry its all kinda self explanitory though you just fit the wraith knuckles on the everest axles very easy Last edited by ferp420; 09-17-2019 at 08:49 PM. | |
Everest 10 broken steering knuckle, what fits as replacement? - Similar Threads | ||||
Redcat everest 10 unboxing and test broken! 😲 | shenlonco | Scale Videos! | 0 | 06-20-2018 03:26 PM |
Everest 10 knuckle weights | Stangman66$ | Redcat Crawlers | 1 | 09-14-2017 10:57 PM |
Replacement battery for redcat Everest 16 stock | SteelEntreri | Newbie General | 3 | 05-01-2016 11:42 AM |
Broken Knuckle and steering issues. | bustedbinder | Axial AX-10 Scorpion | 18 | 08-18-2013 11:46 AM |
