12-01-2019, 05:33 AM | #1 |
Rock Stacker Join Date: Dec 2019 Location: Calabogie, Ontario, Canada
| stand for E10
Hi folks. I am looking for some help in finding a stand for my RCR Everest 10 truck. I have looked on Amazon.ca (I am in Canada) and there are a lot of them but not sure if they would fit the E10. There are some nice metal ones but again not sure if they would fit. I am open for any help and suggestions. Regards Tar |
12-01-2019, 07:09 AM | #2 |
| Re: stand for E10
you would have to mesure the distence from the bottom of the skid plate to the bottom of the tires with the rig off the ground that will give you some #s to work with then you could look up the hight of the stand personaly my e10 sits in the pile with 10 other rcs in the closet but i have anti flat spot tire inserts so i dont worry about flat foams but alot of people just use foam blocks or 4x4 wood blocks i think the stands are more for working on them than storing them im sure someone will chime in with a better answer but i dont use stands so i can5 help much Last edited by ferp420; 12-01-2019 at 07:48 AM. |
12-01-2019, 10:56 AM | #3 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
| Re: stand for E10
Unless you limit the shocks (which I would recommend), you will need a very tall stand because the Everest 10 has quite a bit of wheel travel. I actually used small cardboard boxes as stands. We do quite a bit of on line shopping, so it was easy to find ones that worked.
12-01-2019, 03:42 PM | #4 |
Rock Stacker Join Date: Jun 2016 Location: Squaw Valley
| Re: stand for E10
Crawler Innovations Cell Block. Look it up. It's a block of foam. Your links will mold onto the block. Sent from my SM-N920V using Tapatalk |
12-01-2019, 04:58 PM | #5 |
| Re: stand for E10
I have a cell block. The wheels of the Everest 10 will still touch the ground with a cell block under the skid unless you limit the shock travel.
12-02-2019, 04:22 AM | #6 |
| Re: stand for E10
Thanks folks for the info. I will look at the cell blocks to see. I did see a very nice stand that is metal and has a nice blue color but the long arms that the truck would rest on, I do not think the the E10 would fit on it. Oh well I will continue to look. Thanks again. Regards Tar |
12-04-2019, 07:43 PM | #7 | |
| Re: stand for E10 Quote:
Sent from my SM-N920V using Tapatalk | |
stand for E10 - Similar Threads | ||||
E10 Deadbolt | number9 | Redcat Crawlers | 3 | 01-04-2018 12:07 AM |
E10 r1 | Brandyn | Redcat Crawlers | 5 | 02-08-2017 12:35 PM |
e10 | Greger | Non Crawler RC's | 3 | 04-14-2013 03:20 PM |
