Gen 8 c's and panhard mounting Anybody running the treal brass c's on their gen 8? Got them on mine, they rotate the shock tabs 90*, and my shocks are mounted in the front. Im wondering if using the backside of the shock mount to extend my panhard a bit, and mount it to the brass rather than the flexy stock mount, would be advantageous? |
Re: Gen 8 c's and panhard mounting https://www.amazon.com/Treal-Caster-...0964426&sr=8-7 These are the c's (c hubs, caster mounts etc.) |
Re: Gen 8 c's and panhard mounting if you move.the panhard bar to the front side of the mount then you can run a 30mm screw through your upper link mount and use a rod end to conect to the pan hard bar link and that mount.will never move again and if you realy want to make sure it.lasts get the ssd link mounts there a huge improvement over other designs |
