03-30-2020, 05:07 AM | #1 |
Newbie Join Date: Sep 2019 Location: Warrenton
| Gen 7 Rod Ends
So I've broken a lower link rod end on my Gen 7 and am having a heck of a time finding the right size replacement. I've tried several in my parts bin (RC4WD, Traxxas) but the threaded end on the link is too small. Also, Redcat only seems to sell the links. Not just the rod end. What rod ends are compatible? |
03-30-2020, 06:48 AM | #2 |
| Re: Gen 7 Rod Ends
i think your looking for medium sized rodends theres short medium and long but not all manufacturers sizes are the same if you buy longer rod ends.you can cut them down to what ever size you want the best option is to replace all the rodends with quality rod ends and never have that problem again |
03-30-2020, 07:20 AM | #3 |
| Re: Gen 7 Rod Ends
What size are the threads? Traxxas has difference diameter (for different thread sizes) as well as different length rod ends. |
03-30-2020, 07:45 AM | #4 |
| Re: Gen 7 Rod Ends
The stud threads coming out of the link are 3mm. I bought a pack of RC4WD M3/M4 Z-S1378 Plastic Short Rod Ends but they're too big (not the end itself, just the hole that accepts the stud). In shopping around for ends I'm guessing 4mm is standard because I cant really tell where it's specified. Sent from my SM-G973U using Tapatalk |
03-30-2020, 09:06 AM | #5 | |
| Re: Gen 7 Rod Ends Quote:
03-30-2020, 10:20 AM | #6 |
| Re: Gen 7 Rod Ends
I did a side-by-side with my vanquish links from an Origin I'm putting together. It's on top. The RC4WD end fits it no problem. The Gen 7 threads on the bottom are too small in diameter. Below that is a 3 mm screw and nut - the same diameter as the Gen 7 link stud. What am I missing here? Sent from my SM-G973U using Tapatalk |
03-30-2020, 11:07 AM | #7 |
| Re: Gen 7 Rod Ends
So the ends off an old Tamiya nitro I have work. Back on the trail! Sent from my SM-G973U using Tapatalk |
03-30-2020, 12:25 PM | #8 |
| Re: Gen 7 Rod Ends
Traxxas 5349 have 3mm thread and a 3mm hole in the ball, I used those to repair my son's Gen7, but I don't recall if the width is the same as the Redcat ends.
03-31-2020, 10:31 AM | #9 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Gen 7 Rod Ends Yup. The M3/M4 refers to the ball end hole and the plastic hole, so you bought an end link that accepts an M3 screw through the ball end, but is sized to thread on to an M4 link thread. You need an M3/M3 (usually just called M3) rod end. RC4WD, Traxxas and tons of others make them. I keep a bunch of the long RC4WD links around because that way I can cut them down to any length I need.
03-31-2020, 12:59 PM | #10 | |
Sent from my SM-G973U using Tapatalk | |
Gen 7 Rod Ends - Similar Threads | ||||
will jato rod ends fix my ti rod problem? | J-Fish | Axial XR10 | 8 | 03-19-2013 06:56 PM |
4mm rod for Revo rod ends | rcjackson0926 | Axial XR10 | 11 | 03-03-2011 01:50 PM |
Drilling Holes into Delrin rod for rod ends | FDAapproved | Losi Mini-Rock Crawler | 10 | 02-13-2009 03:44 PM |
