11-14-2020, 01:03 PM | #1 |
Newbie Join Date: Apr 2011 Location: Green River
| Wendigo Compatible Beadlocks
Does anyone know which aftermarket 2.2 beadlock wheels fit on the wendigo without rubbing? Thanks for your help
11-15-2020, 07:25 AM | #2 | |
| Re: Wendigo Compatible Beadlocks Quote:
The Slw hub is just a bolt on hub uses 6 bolts to hold the hub to the wheel The wheel will have a big hole in the middle with 6 bolt holes around it the usually come with a hub and most likely it will fit with out issues if not try a hub with more offset Also there are different size hexs from 12x5 up to 12x25 if you don't want to get Slw style wheels Just get what ever wheels you like then space them out till they don't rub anymore | |
11-26-2020, 11:12 AM | #3 |
Rock Crawler Join Date: Mar 2012 Location: UK
I’ve got cheapo Injora beadlocks with 15mm hubs and they fit fine
Wendigo Compatible Beadlocks - Similar Threads | ||||
1.9 beadlocks compatible with Rock Beasts | HockmanRCBoys | Tires and Wheels | 15 | 10-03-2016 07:54 PM |
