03-06-2021, 07:16 PM | #1 |
Newbie Join Date: Jun 2018 Location: Grass Valley
| Gen8 Springs
Looking for a set of softer springs. Any ideas.
03-07-2021, 07:16 AM | #2 |
| Re: Gen8 Springs
you could take the adjusters off the top of the shocks if you want to lower it some more also the gen8 shocks are close enuff in size to other brands of shocks so most springs for say axial should work |
03-08-2021, 11:13 AM | #3 |
| Re: Gen8 Springs
Thanks for reply. Going to try some Traxxas springs. Will post results after springs show up. Cheers
03-08-2021, 01:45 PM | #4 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Gen8 Springs |
03-14-2021, 03:47 PM | #5 |
| Re: Gen8 Springs
Okay, did go with the Traxxas yellow springs. They're working great. Were shorter than stock ones, but turned down adjusters. Also changed out bottom shock mount to old Axial ones I had. Now springs seat good. Did this only on rear shocks, as fronts are taking the most weight of the kit build. Cheers.
Gen8 Springs - Similar Threads | ||||
oil shocks w/leaf springs (no coil springs) | VR6 BeelzeDub | G-Made Sawback | 9 | 05-18-2016 07:52 AM |
Schock-Setup - why run internal springs, or no springs? | Turbo-s | Axial XR10 | 3 | 02-10-2012 09:16 AM |
Custom Deaver Springs or ARB OMU springs | Agama | Chit Chat | 8 | 08-08-2011 01:31 PM |
