03-08-2022, 02:07 PM | #1 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Gen8 AXE Driveshafts
Hello all, It looks like the driveshafts have finally developed enough slop in them that I am going to replace them prior to failing. Just a quick search did not yield much discussions on them and a Google search only brought up s few different items listed as available. Who has upgraded their driveshafts (all 3)? What MFG did you go with and are you happy with them? Are there driveshafts from another brand of vehicle that will fit? If so, are modifications required? Thank you |
03-08-2022, 02:47 PM | #2 |
| Re: Gen8 AXE Driveshafts
I picked up the Redcat steel driveshafts and they're designed wrong, splines dont allow you to properly phase the driveshaft. But I've just lived with it so I'm not sure what a better option is. I believe it uses a standard 5mm (output) shafts so you should have tons of options, just look for an appropriate length. |
03-08-2022, 03:32 PM | #3 | |
| Re: Gen8 AXE Driveshafts Quote:
03-08-2022, 04:25 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Mudville
I'm sure there would be an SSD option, just need to find the lengths and compare. SSD Driveshafts are solid and they should have something that would fit fine.
03-08-2022, 08:32 PM | #5 |
axial style shafts fit no problem i just did the 2 lower shafts i dont see any were on the short shaft it dosent get the beating the others do just get the right langht and your good |
03-08-2022, 10:52 PM | #6 | ||
It’ll give me a good reason to pull the transmission and transfer case out to check the bearings and grease everything up. | ||
Gen8 AXE Driveshafts - Similar Threads | ||||
Gen8 axe or.... | davelopez0811 | Newbie General | 3 | 09-11-2020 10:38 PM |
Gen8 scout or axe edition? | ianpurdy1 | Redcat Crawlers | 8 | 04-29-2020 10:13 PM |
Husky links on gen8 axe | SSMURPHY | Redcat Crawlers | 9 | 03-13-2020 09:49 AM |
Are gen8 Axe shocks normally spongy? | BA0701 | Redcat Crawlers | 3 | 01-25-2020 11:35 PM |
