Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: gen7 super secret service build
Old 11-14-2022, 08:12 AM   #21
Default Re: gen7 super secret service build
the gears finally showed up they got lost in the mail and of course i ordered another set then the first set showed up lol next build i guess
i thought i had all the bearings but i dident i only had enuff to do the front axle
ill get a pic once i cut the front driveshaft down to fit i ordered the right size but i got one thats way too long no big deal though the splines go all the way through
so i am waiting on 4 bearings to show up now and then ill be able to drive this thing
ferp420 is offline   Reply With Quote
Old 12-02-2022, 09:43 AM   #22
i got my bearings and the gears installed i went to cut down my drive shaft and i thought the splines went all the way through but i was wrong so i had to make a few more cuts and welded the peices back together and it works i think its plenty strong but only time will tell
the upside is its the perfict langht now
i have it running and driving i still need to pull it apart and paint the chassie and sleave the links
i might take it out for a test crawl but its still needs a bit of work so far im happy with but ill see when it hits the rocks it it works how i want it too
any way driveshaft pics
Old 12-18-2022, 08:26 PM   #23
i got this rig out for a shake down run i ran it with my gen8 it kept up for the most part the smaller tires and stiff foams and straight axles kinda hert it in places but not as bad as the front bumper lol
all and all it kicked but ran for about 30 min and no breakadge it needs some tuning and a real motor that old redcat motor has to go lol oh well it works anyway
heres a link to the video
https://rumble.com/v21c75c-new-cat-o...tom-gen-8.html
Old 01-16-2023, 09:31 AM   #24
after a few test runs it really needs some forward waight bias so i picked up some brass knuckles so add another $20 to the total
also the wheels were tucked under the fenders and that made it hard to get a side bite so i added wheel spacers i had laying around so no extra cost there
and that pesky redcat motor well the test run took care of that it went up in smoke lol so to keep things consitant with my gen8 i picked up another 13t crawlmaster sport so add another $20
since the knuckles and first motor were just laying around i dident add the cost of those in so ill add the new stuff to the cost but even at that its a good price for a built fully upgraded gen7 pro
when the motor comes in ill give it another test run and post up another video
Old 01-21-2023, 07:34 AM   #25
Pretty cool stuff bud. May be a dumb question but where did you get that plastic? I tried looking it up with no luck. And are you tapping the holes?
Runnin2live is offline   Reply With Quote
Old 01-21-2023, 07:35 AM   #26
Ok I missed it. Cutting board plastic. Whoops
Old 01-21-2023, 11:03 AM   #27
its just 1/4 thick styrene same as the cutting boards they used to sell everywere
the cutting board is more of a term used back in the day when people would buy cutting boards and make chassis out of them before all the desktop cnc machines and 3d printers and pre made chassis
i had a 4x8 sheet of it i have half of it left now i use it for all kinds of things i also have a 3x5ft 1/2" thick sheet but i havent used any of it yet
i havent tapped any holes i do predrill the holes though most of the time i have a nut on the back side unless its a deep hole
some places i dont even use screws just a peice of 2.5mm solid rod and shove it in the hole and it stays there till i pull it out
this stuff is really easy to work with its crazy and kinda fun
gen7 super secret service build - Similar Threads
My Gen7 Build bbolden516 Redcat Crawlers 4 04-28-2021 05:30 PM
Super customer service desertdude Axial Yeti 2 03-19-2015 04:17 PM
Kingsman the Secret Service iljitghn New York 0 02-21-2015 03:47 AM
