12-09-2010, 11:50 PM | #121 | |
Pebble Pounder Join Date: Oct 2010 Location: Castro Valley
What is redneckjiujitsu! I Have to know!!!! | |
12-30-2010, 03:17 AM | #122 |
Rock Stacker Join Date: Nov 2010 Location: indianapolis
I'm in a fantasy league on ufc.com and thought it was a clever name to the fighting style of brazilian jiu jitsu..
01-01-2011, 10:35 PM | #123 |
easy cheap weight for your tire foams... stock foams with weight held in place with fishing line think there 1/2 sinkers so doesnt take much to add a lot of weight these foams came with the rovers, i flipped the foam wrong side out and took a hobby knife cut places to put weights so a 2 ways to get weight inside ur tires for either cut foams or not cut foams |
01-27-2011, 06:27 AM | #124 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
I'm very new to the RC thing but I enjoy 1:1 rock crawling for years! I bought a RS10 witch last me some 40min of run time since it broke the conector on the front motor... I'm waiting for a replacement. On those 40min of run time I saw that the mounting point of the shocks on the links were a dragging spot. Using nothing but ingenuity and a swiss army knife (MacGeyver would be proud!), I tried to fix that with some pen caps! Here are some pictures: I put some double side tape and zip tied them so they can glue properly... Now I just have to do some ajustments and wait for the new motor to test... |
02-03-2011, 09:26 AM | #125 |
Newbie Join Date: Dec 2010 Location: Palmdale
| My rs10 Body and mods from ZNO. http://s1111.photobucket.com/albums/...DSC02142-1.jpg" target="_blank">http://i1111.photobucket.com/albums/...DSC02142-1.jpg" border="0" alt="Photobucket"> Last edited by kamakazi1; 02-03-2011 at 09:34 AM. Reason: I don't know what i'm doing. |
03-02-2011, 05:53 PM | #126 |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
| Mod for tires oulling wires off motor fix
I'm sure everyone is aware of a way to keep the tires from ripping the wires off the motor, but I figures I would throw this up here anyways. I notice my rovers were getting the wires after I increased the servo throw and cut the stops off the axle so I decided to put two layers of electrical tape over the wires and hoven't had a problem since, the tires are not hard enough to cause abrasion to the tape. There is just enough room in between the motor vents to stick the tape and I have noticed no extra heating after the tape. Heres some pics. I run the poo out of this little guy and the tape has held up fine and saved me wires! |
03-03-2011, 04:59 PM | #127 | |
Newbie Join Date: Dec 2010 Location: newcastle
How did you get more steering throw out of you servo? What servo are you running? | |
03-14-2011, 12:12 PM | #128 |
Pebble Pounder Join Date: Mar 2011 Location: Saxonia
more steering is not the problem, but if u cut the mechanical stoppers on the axle u can get loose the fitting of the dogbones
03-21-2011, 10:18 PM | #129 |
Newbie Join Date: Mar 2011 Location: Puerto Rico
Well, I don't know if is a tip or trick, but it worked nicely to store my redcat. You will have to set loose the antenna in order to lay it down. |
06-01-2011, 06:19 PM | #130 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Zno big boy 540 swap
Here is a full documented conversion to 540's using ZNO's aftermarket housings for 540's, the "BIG BOY" kit. ZNO 540 swap, Documented; |
08-10-2011, 11:04 AM | #131 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
This may be a stupid question, so brace yourselves. What is the purpose behind moving the shock mounts to the axle from the links? What does it improve?
08-10-2011, 11:35 AM | #132 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
| Doing that, in addition to 4 linking the suspension links, can limit your articulation. No rig needs 90 degrees of articulation, so limiting that down makes your rig more predictable rather than articulating like a contortionist every time it hits a rock. The plastic mounts that are on the links kinda suck and can slide on the links. I also think it looks better having them mounted to the axle.
08-10-2011, 12:24 PM | #133 | |
here's one to show the articulation that it has now. | |
08-29-2011, 03:08 AM | #134 | |
Newbie Join Date: Aug 2011 Location: Lincoln City
10-08-2011, 04:47 PM | #135 |
Rock Stacker Join Date: Sep 2011 Location: Oceanside
I had a small motor issue today. The rear motor locked so when I got home I took it off the truck. I could see thru the cooling slots that the plastic fan had come loose from the shaft and was wedging up against the brush assembly. I peeled the 4 tabs back and cut the 2 capacitors from the outer can. Once the cap was removed the fan fell out. I repositioned it and mixed up some 5 minuete epoxy and dabbed a little on the top of the windings to the fan in 3 different spots. Re assembled and re soldered the caps then wired up to my Checkpoint charger and did a 20 minuete break in at 1.3V When it was done I swear the motor runs smoother than the front one. Maybe I'll take it out and run it too. Last edited by 1320Fastback; 10-08-2011 at 04:49 PM. |
11-07-2011, 03:12 PM | #136 |
Newbie Join Date: Nov 2011 Location: Lakeside
| Newbie needs some advise
Hi All, I am a 61 year old NEWBIE to all this RC stuff.I was wonder what brand of tires I could get to replace my stock ones on mt RS 10 XT ? Thanks in advance for any advise.. Steve / Lakeside,Az. |
11-07-2011, 04:28 PM | #137 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| white dot hot bodies rovers (ckrc.com they r bout 12 bucks a pair) trust me u will b pleased i think the best tire for the money and add some stick on wheel weights to the front rims while u have them apart
11-07-2011, 04:42 PM | #138 |
Newbie Join Date: Nov 2011 Location: pine bluff
which tire would be better the rock crushers or the super swamper boggers . my rx10 is not just for rocks but mud and dirt has anyone tried thes tires
11-07-2011, 05:25 PM | #139 |
This thread isn't the ideal place to ask questions about which part is the best. It is, however, a good place to share a tech tip or mod that you come up with. That said, it would be easier in the future to just start a new thread or search the hundreds of threads about tires to get some opinions. chuggyII - depends on your budget and what you're looking for out of a tire. If you want something that flat out performs, the white dot rovers are a great choice, but so are the other aftermarket comp tires, such as panther leopards, cougars, losi boss claws and comp claws, hot bodies rovers and sedonas, the list goes on and on. None of those would be bad, and you'd likely be happy with any of them. gduck - I don't have experience with either tire, but based on looks alone, the super swampers would probably be a better choice for mud and dirt, and would likely work well on rock also. |
11-15-2011, 10:30 AM | #140 |
Newbie Join Date: Nov 2011 Location: Metropolis
| RS10 Motors 380 vs 390
Hello everyone , i`ve been reading all the great ideas and tips here and can`t wait to get my red cat,while searching the internet for the best price w/free ship ( on a budget gotta save my cash for upgrades ),i discovered that the older version is still available with the 380 motors, while the XT model has newer 390 motors. In several posts about the older RS10 some members recommended replacing 380`s with aftermarket 390`s, my question is , if i upgrade the servos and tires ,will this stock motor be good enough or can you recommend a better 390 ? ordering mine today ,found the XT for $155 w/ free ship, i think i`m gonna 2 day ship tho to get it here this week . ( still a big kid lol but then ain`t we all). Thanks Don " I take mine on the Rocks ,shaken not stirred" |
