04-03-2012, 01:48 AM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Tuning the stock chassis So, the stock RS-10 chassis doesn't come with a whole lot of tuning options built into it. It's entire design is based on the stock On-the-link shock mounts and high ride height. BUT, That doesn't mean you can't make it better. It's just two aluminium plates. You can cut and drill whatever you like on it!! For example; A lot of guys drill a hole in the furthest front and rear points of the chassis for a new shock mounting point, closer to the axles, to do the shock-to-axle-mount mod. Some guys even add extensions on to the chassis to get a more 'scale' setup. If its a higher belly clearance AND/OR lower center of gravity that you are after, you can cut down the chassis to give it a lower profile. If you plan to do this, try to plan out where you want to mount your links and shocks first, before you go cutting out something important. Here's a few examples of how some members have customized their chassis setups; If you have a custom Chopped RS-10 chassis on your ride ******POST IT HERE****** Jason "The Jackalope" |
04-03-2012, 04:40 AM | #2 |
Pebble Pounder Join Date: Sep 2010 Location: Brussels/Belgium
| Re: Tuning the stock chassis
Here is mine: Belly cut off and few new holes |
04-05-2012, 04:11 AM | #3 |
Newbie Join Date: Dec 2011 Location: Springfield
has anyone used the zno-rc narrowed chassis setup or their chassis plates? wondering how well the stock would be narrowed.
Tuning the stock chassis - Similar Threads | ||||
Stock chassis to Chaotic chassis...shorter wheelbase...fixed | OhioCrawler | Axial XR10 | 34 | 03-20-2012 12:47 PM |
ANy tips for tuning the suspension with the stock plates? | ReaperGN | Kyosho Crawlers | 4 | 04-23-2011 11:57 PM |
scaler chassis out of a stock chassis? | NEW YORK BOY | HPI Wheely King | 0 | 05-04-2010 09:42 PM |
